Analog Devices - Case Codes
05-08-1110 J14 DIP, 7.62 mm lead span, 2.54 mm pitch; 14 pin, 19.939 mm L X 6.731 mm W X 5.08 mm H body
05-08-1110 J16 DIP, 7.62 mm lead span, 2.54 mm pitch; 16 pin, 21.336 mm L X 6.731 mm W X 5.08 mm H body
05-08-1110 J8 DIP, 7.62 mm lead span, 2.54 mm pitch; 8 pin, 10.287 mm L X 6.731 mm W X 5.08 mm H body
05-08-1210 D14 DIP, 7.62 mm lead span, 2.54 mm pitch; 14 pin, 19.304 mm L X 7.366 mm W X 5.716 mm H body
05-08-1210 D16 DIP, 7.62 mm lead span, 2.54 mm pitch; 16 pin, 21.336 mm L X 7.366 mm W X 5.716 mm H body
05-08-1210 D18 DIP, 7.62 mm lead span, 2.54 mm pitch; 18 pin, 23.114 mm L X 7.366 mm W X 5.716 mm H body
05-08-1210 D20 DIP, 7.62 mm lead span, 2.54 mm pitch; 20 pin, 25.654 mm L X 7.366 mm W X 5.716 mm H body
05-08-1210 D8 DIP, 7.62 mm lead span, 2.54 mm pitch; 8 pin, 13.208 mm L X 7.366 mm W X 5.716 mm H body
05-08-1250 L20 Leadless Chip Carrier (LCC), 1.27 mm pitch; rect., 6 pin X 4 pin, 10.925 mm L X 7.43 mm W X 1.95 mm H body
05-08-1260 LS20 Leadless Chip Carrier (LCC), 1.27 mm pitch; square, 5 pin X 5 pin, 8.89 mm L X 8.89 mm W X 2.29 mm H body
05-08-1320 H8 TO Cylindrical Style, 2.54 mm pitch; 8 pin, 9.398 mm W X 5.842 mm H body
05-08-1321 H8 TO Cylindrical Style, 2.921 mm pitch; 8 pin, 9.398 mm W X 5.842 mm H body
05-08-1322 H10 TO Cylindrical Style, 2.921 mm pitch; 10 pin, 9.398 mm W X 5.842 mm H body
05-08-1330 H3 TO Cylindrical Style, 2.54 mm pitch; 3 pin, 9.398 mm W X 4.699 mm H body
05-08-1331 H4 TO Cylindrical Style, 2.54 mm pitch; 4 pin, 9.398 mm W X 4.699 mm H body
05-08-1340 H3 TO Cylindrical Style, 1.27 mm pitch; 3 pin, 5.537 mm W X 2.667 mm H body
05-08-1341 H4 TO Cylindrical Style, 1.27 mm pitch; 4 pin, 5.563 mm W X 2.667 mm H body
05-08-1350 H3 TO Cylindrical Style, 1.27 mm pitch; 3 pin, 5.842 mm W X 3.81 mm H body
05-08-1420 T3 Flange Mount (TO-220) Vertical, 2.54 mm pitch; 3 pin, 10.541 mm L X 4.572 mm W X 22.149 mm H body
05-08-1421 T5 Flange Mount (TO) vert., 1.70 mm pitch; 5 pin, 10.541 mm W X 4.572 mm H X 22.149 mm mounted height
05-08-1421 T5 Flange Mount (TO-220) Vertical, 1.70 mm pitch; 5 pin, 10.541 mm L X 4.572 mm W X 22.149 mm H body
05-08-1422 T7 Flange Mount (TO-220) Vertical, 1.27 mm pitch; 7 pin, 10.541 mm L X 4.572 mm W X 22.149 mm H body
05-08-1450 K3 Regulator; 2 pin, 35.00 mm L X 12.954 mm W X 8.89 mm H body
05-08-1450 P3 Flange Mount (TO-220) Vertical, 5.46 mm pitch; 3 pin, 16.26 mm L X 5.26 mm W X 26.42 mm H body
05-08-1460 M3 DPAK, 2.54 mm pitch; 4 pin, 8.89 mm L X 10.22 mm W X 4.57 mm H body
05-08-1461 Q5
05-08-1461 Q5 DPAK, 1.70 mm pitch; 6 pin, 8.89 mm L X 10.22 mm W X 4.57 mm H body
05-08-1462 R7 DPAK, 1.27 mm pitch; 8 pin, 8.89 mm L X 10.224 mm W X 4.57 mm H body
05-08-1500 UFF44 Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; rect., 15 pin X 7 pin, 7.00 mm L X 4.00 mm W X 0.80 mm H body
05-08-1502 BGA25 Ball Grid Array (BGA), 1.27 mm pitch, square; 25 pin, 6.25 mm L X 6.25 mm W X 2.62 mm H body
05-08-1504 LGA144 Land Grid Array (LGA), 1.27 mm pitch, square; 144 pin, 16.00 mm L X 16.00 mm W X 2.01 mm H body
05-08-1508 LGA77 Land Grid Array (LGA), 1.27 mm pitch, rect; 77 pin, 15.00 mm L X 9.00 mm W X 1.92 mm H body
05-08-1510 N14 DIP, 7.62 mm lead span, 2.54 mm pitch; 14 pin, 19.558 mm L X 6.477 mm W X 3.937 mm H body
05-08-1510 N14 DIP, 7.62 mm lead span, 2.54 mm pitch; 14 pin, 19.558 mm L X 6.477 mm W X 4.037 mm H body
05-08-1510 N16 DIP, 7.62 mm lead span, 2.54 mm pitch; 16 pin, 19.558 mm L X 6.477 mm W X 3.937 mm H body
05-08-1510 N16 DIP, 7.62 mm lead span, 2.54 mm pitch; 16 pin, 19.558 mm L X 6.477 mm W X 4.037 mm H body
05-08-1510 N18 DIP, 7.62 mm lead span, 2.54 mm pitch; 18 pin, 23.368 mm L X 6.477 mm W X 3.937 mm H body
05-08-1510 N18 DIP, 7.62 mm lead span, 2.54 mm pitch; 18 pin, 23.368 mm L X 6.858 mm W X 4.037 mm H body
05-08-1510 N20 DIP, 7.62 mm lead span, 2.54 mm pitch; 20 pin, 26.416 mm L X 6.858 mm W X 4.037 mm H body
05-08-1510 N20 DIP, 7.62 mm lead span, 2.54 mm pitch; 20 pin, 26.924 mm L X 6.477 mm W X 3.937 mm H body
05-08-1510 N24 DIP, 7.62 mm lead span, 2.54 mm pitch; 24 pin, 31.131 mm L X 6.858 mm W X 4.037 mm H body
05-08-1510 N24 DIP, 7.62 mm lead span, 2.54 mm pitch; 24 pin, 32.512 mm L X 6.477 mm W X 3.937 mm H body
05-08-1510 N28 DIP, 7.62 mm lead span, 2.54 mm pitch; 28 pin, 35.56 mm L X 6.477 mm W X 3.937 mm H body
05-08-1510 N28 DIP, 7.62 mm lead span, 2.54 mm pitch; 28 pin, 35.56 mm L X 7.493 mm W X 4.037 mm H body
05-08-1510 N8 DIP, 7.62 mm lead span, 2.54 mm pitch; 8 pin, 10.16 mm L X 6.477 mm W X 3.937 mm H body
05-08-1510 N8 DIP, 7.747 mm lead span, 2.54 mm pitch; 8 pin, 10.29 mm L X 7.874 mm W X 5.08 mm H body
05-08-1510 NW28 DIP, 15.24 mm lead span, 2.54 mm pitch; 28 pin, 36.957 mm L X 14.224 mm W X 3.937 mm H body
05-08-1511 LQFN24 Quad Flat No-Lead (QFN) with tab; 32 pin, 4.00 mm L X 4.00 mm W X 1.03 mm H body
05-08-1512 LQFN32 Quad Flat No-Lead (QFN); 42 pin, 6.20 mm L X 4.20 mm W X 1.03 mm H body
05-08-1515 BGA42 Ball Grid Array (BGA), 0.80 mm pitch, rect.; 42 pin, 6.00 mm L X 5.00 mm W X 1.50 mm H body
05-08-1516 LQFN16 Quad Flat No-Lead (QFN) with tab; 21 pin, 3.00 mm L X 3.00 mm W X 1.03 mm H body
05-08-1517 BGA28 Ball Grid Array (BGA), 0.80 mm pitch, rect.; 28 pin, 6.25 mm L X 4.00 mm W X 2.42 mm H body
05-08-1518 Ball Grid Array (BGA), 0.80 mm pitch, square; 49 pin, 6.25 mm L X 6.25 mm W X 2.42 mm H body
05-08-1518, BGA49 Ball Grid Array (BGA), 0.80 mm pitch, square; 49 pin, 6.25 mm L X 6.25 mm W X 2.42 mm H body
05-08-1519 LQFN20 Quad Flat No-Lead (QFN) with tab; 24 pin, 4.00 mm L X 3.00 mm W X 0.84 mm H body
05-08-1520 NW28 DIP, 15.24 mm lead span, 2.54 mm pitch; 28 pin, 36.957 mm L X 14.224 mm W X 4.418 mm H body
05-08-1523 BGA144 Ball Grid Array (BGA), 1.27 mm pitch, square; 144 pin, 16.00 mm L X 16.00 mm W X 5.21 mm H body
05-08-1525 LQFN36 Quad Flat No-Lead (QFN) with tab; 46 pin, 7.00 mm L X 4.00 mm W X 1.03 mm H body
05-08-1528 UHG40 Quad Flat No-Lead (QFN) with tab; 41 pin, 8.00 mm L X 5.00 mm W X 0.80 mm H body
05-08-1530 Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 4 pin X 2 pin, 2.00 mm L X 2.00 mm W X 0.83 mm H body
05-08-1530 LQFN12 Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 4 pin X 2 pin, 2.00 mm L X 2.00 mm W X 0.83 mm H body
05-08-1535, BGA88 Ball Grid Array (BGA), 1.00 mm pitch, rect.; 88 pin, 11.25 mm L X 9.00 mm W X 3.52 mm H body
05-08-1536 UDC20 Quad Flat No-Lead (QFN); 24 pin, 4.00 mm L X 3.00 mm W X 0.80 mm H body
05-08-1537 UDD24 Quad Flat No-Lead (QFN); 26 pin, 5.00 mm L X 3.00 mm W X 0.80 mm H body
05-08-1538 UFD28 Quad Flat No-Lead (QFN); 34 pin, 5.00 mm L X 4.00 mm W X 0.80 mm H body
05-08-1542 BGA77 Ball Grid Array (BGA), 1.27 mm pitch, rect.; 77 pin, 15.00 mm L X 9.00 mm W X 3.71 mm H body
05-08-1548 LQFN18 Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; 19 pin, square, 4 pin X 5 pin, 3.00 mm L X 3.00 mm W X 1.03 mm H body
05-08-1552 LQFN28 Quad Flat No-Lead (QFN) with tab; 36 pin, 5.00 mm L X 4.00 mm W X 0.83 mm H body
05-08-1559 BGA77 Ball Grid Array (BGA), 1.27 mm pitch, rect.; 77 pin, 15.00 mm L X 9.00 mm W X 2.62 mm H body
05-08-1560 LGA76 Land Grid Array (LGA), 1.27 mm pitch, rect; 76 pin, 15.00 mm L X 11.25 mm W X 4.42 mm H body
05-08-1563 LGA108
05-08-1566 BGA25 Ball Grid Array (BGA), 0.65 mm pitch, square; 25 pin, 4.00 mm L X 4.00 mm W X 1.98 mm H body
05-08-1568 BGA330
05-08-1571 Quad Flat No-Lead (QFN) with tab; 43 pin, 5.00 mm L X 8.00 mm W X 1.05 mm H body
05-08-1573 Ball Grid Array (BGA), 0.80 mm pitch, square; 49 pin, 6.25 mm L X 6.25 mm W X 4.21 mm H body
Page 1 of 15
