| 0201, 0603 Metric |
Inductor, Chip; 0.60 mm L X 0.30 mm W X 0.28 mm H body |
| 0402, 1005 Metric |
Inductor, Chip; 1.00 mm L X 0.50 mm W X 0.37 mm H body |
| 0402, 1005 Metric |
Thermistor, Chip; 1.00 mm L X 0.50 mm W X 0.65 mm H body |
| AB |
Crystal, HC-49; 4.88 mm C X 0.457 mm W 11.30 mm L X 4.90 mm T X 13.46 mm H body |
| AB-22 |
Crystal, HC-49; 4.88 mm pitch X 0.457 mm T, 11.30 mm L X 4.90 mm W X 13.46 mm H body |
| AB-RTCMC |
Oscillator; 10 pin, 3.70 mm L X 2.50 mm W X 0.90 mm H body |
| AB-RTCMC |
Oscillator; 8 pin, 3.20 mm L X 1.50 mm W X 0.80 mm H body |
| AB26TRB |
Oscillator; 3 pin, 6.00 mm L X 1.90 mm W X 2.00 mm H body |
| AB26TRJ |
Crystal; 3 pin, 9.60 mm L X 3.90 mm W X 2.90 mm H body |
| AB26TRQ |
Crystal; 3 pin, 7.60 mm L X 1.80 mm W X 1.48 mm H body |
| AB308 |
Capacitor, Radial (Dipped), round; 1.40 mm C X 3.10 mm Dia. X 8.20 mm H body |
| ABC2 |
Oscillator, Side Concave, 5.08 mm pitch; 4 pin, 11.80 mm L X 5.50 mm W X 2.00 mm H body |
| ABL |
Crystal, HC-49; 4.88 mm C X 0.457 mm W 11.50 mm L X 5.00 mm T X 3.50 mm H body |
| ABL |
Crystal, HC-49; 4.88 mm pitch X 0.457 mm W, 11.50 mm L X 5.00 mm T X 3.50 mm H body |
| ABLJO |
Oscillator, Side Concave, 2.54 mm pitch; 6 pin, 14.30 mm L X 8.70 mm W X 5.50 mm H body |
| ABLJO |
Oscillator, Side Concave; 1 pin, 7.15 mm L X 4.35 mm W X 5.50 mm H body |
| ABLJO |
Oscillator, Side Concave; 6 pin, 14.30 mm L X 8.70 mm W X 5.50 mm H body |
| ABLNO |
Oscillator, Side Concave, 5.08 mm pitch; 4 pin, 14.30 mm L X 8.70 mm W X 5.50 mm H body |
| ABLNO |
Oscillator, Side Concave; 4 pin, 14.30 mm L X 8.70 mm W X 5.50 mm H body |
| ABLS |
Crystal; 11.40 mm L X 4.70 mm W X 4.20 mm H body |
| ABLS |
Crystal; 11.40 mm L X 4.70 mm W X 4.30 mm H body |
| ABLS-LR |
| ABLS2 |
Crystal; 11.40 mm L X 4.70 mm W X 3.30 mm H body |
| ABLS3 |
Crystal; 11.40 mm L X 4.70 mm W X 2.50 mm H body |
| ABLS7M |
Crystal; 7.00 mm L X 3.80 mm W X 2.30 mm H body |
| ABLS7M2 |
Crystal; 7.00 mm L X 3.80 mm W X 2.00 mm H body |
| ABLS7M2 |
Crystal; 7.00 mm L X 4.00 mm W X 2.00 mm H body |
| ABLSG |
Crystal (HC49); 3 pin, 11.40 mm L X 4.70 mm W X 4.20 mm H body |
| ABM10 |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 1.65 mm pitch; 4 pin, 2.50 mm L X 2.00 mm W X 0.70 mm H body |
| ABM10-167 |
Oscillator, Corner Concave; 2.50 mm L X 2.00 mm W X 0.50 mm H body |
| ABM10AIG |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 1.65 mm pitch; 4 pin, 2.55 mm L X 2.05 mm W X 0.65 mm H body |
| ABM10W |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 1.625 mm pitch; 4 pin, 2.50 mm L X 2.00 mm W X 0.65 mm H body |
| ABM11 |
Crystal; 4 pin, 2.15 mm L X 1.75 mm W X 0.59 mm H body |
| ABM11 |
Oscillator, Corner Concave; 2.00 mm L X 1.60 mm W X 0.59 mm H body |
| ABM11 |
Oscillator, Corner Concave; 2.00 mm L X 1.60 mm W X 2.00 mm H body |
| ABM11 |
Oscillator, Dual Flat No-Lead (DFN 4 Pins), 1.30 mm pitch; 4 pin, 2.00 mm L X 1.60 mm W X 0.59 mm H body |
| ABM11AIG |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 1.275 mm pitch; 4 pin, 2.00 mm L X 1.60 mm W X 0.55 mm H body |
| ABM11W |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 1.275 mm pitch; 4 pin, 2.00 mm L X 1.60 mm W X 0.50 mm H body |
| ABM12 |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 1.00 mm pitch; 4 pin, 1.60 mm L X 1.20 mm W X 0.45 mm H body |
| ABM12W |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 1.00 mm pitch; 4 pin, 1.60 mm L X 1.20 mm W X 0.40 mm H body |
| ABM13 |
Oscillator, Corner Concave; 1.20 mm L X 1.00 mm W X 0.59 mm H body |
| ABM13W |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 0.69 mm pitch; 4 pin, 1.20 mm L X 1.00 mm W X 0.33 mm H body |
| ABM2 |
Crystal, Side Lead; 2 pin, 4.50 mm L X 8.00 mm W X 1.60 mm H body |
| ABM3 |
Crystal, Side Lead; 2 pin, 3.20 mm L X 5.00 mm W X 1.30 mm H body |
| ABM3B |
Oscillator, Corner Concave; 5.00 mm L X 3.20 mm W X 1.10 mm H body |
| ABM3C |
Oscillator, Corner Concave; 5.00 mm L X 3.20 mm W X 1.30 mm H body |
| ABM3X |
Oscillator, Corner Concave; 5.00 mm L X 3.20 mm W X 0.90 mm H body |
| ABM7 |
Crystal, Side Lead; 2 pin, 3.50 mm L X 6.00 mm W X 1.30 mm H body |
| ABM7 |
Crystal, Side Lead; 2 pin, 3.50 mm L X 6.00 mm W X 1.40 mm H body |
| ABM8 |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 2.10 mm pitch; 4 pin, 3.20 mm L X 2.50 mm W X 0.80 mm H body |
| ABM8 |
Oscillator, Corner Concave; 3.20 mm L X 2.50 mm W X 0.80 mm H body |
| ABM8-166 |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 2.10 mm pitch; 4 pin, 3.20 mm L X 2.50 mm W X 0.70 mm H body |
| ABM81 |
| ABM8AIG |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 2.20 mm pitch; 4 pin, 3.20 mm L X 2.50 mm W X 0.80 mm H body |
| ABM8G |
Oscillator, Corner Concave; 3.20 mm L X 2.50 mm W X 0.75 mm H body |
| ABM8G |
Oscillator, Corner Concave; 3.20 mm L X 2.50 mm W X 1.00 mm H body |
| ABM8W |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 2.20 mm pitch; 4 pin, 3.20 mm L X 2.50 mm W X 0.75 mm H body |
| ABM8X |
Oscillator, Corner Concave; 3.20 mm L X 2.50 mm W X 0.60 mm H body |
| ABM9 |
Oscillator, Corner Concave; 4.00 mm L X 2.50 mm W X 0.80 mm H body |
| ABMC2 |
Crystal; 4 pin, 11.00 mm L X 5.00 mm W X 2.00 mm H body |
| ABMM |
Crystal; 4 pin, 7.00 mm L X 5.00 mm W X 1.30 mm H body |
| ABMM |
Crystal; 4 pin, 7.20 mm L X 5.20 mm W X 2.00 mm H body |
| ABMM2 |
Oscillator, Corner Concave; 6.00 mm L X 3.60 mm W X 1.20 mm H body |
| ABNTC-0402 |
| ABS04W |
Crystal, Dual Flat No-Lead (DFN 4 Pins), 0.74 mm pitch; 4 pin, 1.20 mm L X 1.00 mm W X 0.35 mm H body |
| ABS05 |
Crystal, Dual Flat No-Lead, 2 pin; 1.60 mm L X 1.00 mm W X 0.50 mm H body |
| ABS05W |
Crystal, Dual Flat No-Lead (DFN) 2 pins; 1.60 mm L X 1.00 mm W X 0.50 mm H body |
| ABS06 |
Crystal, Dual Flat No-Lead, 2 pin; 2.00 mm L X 1.20 mm W X 0.60 mm H body |
| ABS06L |
| ABS07 |
Crystal, Dual Flat No-Lead (DFN) 2 pins; 3.20 mm L X 1.50 mm W X 0.90 mm H body |
| ABS07AIG |
Crystal, Dual Flat No-Lead, 2 pin; 3.20 mm L X 1.50 mm W X 0.90 mm H body |
| ABS07L |
| ABS09 |
Crystal, Dual Flat No-Lead, 2 pin; 4.10 mm L X 1.50 mm W X 0.90 mm H body |
| ABS10 |
| ABS10 |
Crystal, Dual Flat No-Lead, 2 pin; 4.90 mm L X 1.80 mm W X 1.00 mm H body |
