TE Connectivity - Case Codes
2232532-2
2232532-3
2232532-4
2232532-5
2232532-7
2232532-8
2232580-5
2246092-2 Spring Contact; 4 pin, 5.20 mm L X 5.20 mm W X 1.626 mm H body
226990-1 Connector, BNC Right Angle; 2 pin, 35.56 mm L X 14.76 mm W X 16.13 mm H body
2274845-1 Connector, Right Angle Receptacle; 104 pin, 34.30 mm L X 10.45 mm W X 6.90 mm H body
2284170-1 Connector, Card Edge Right Angle; 81 pin, 77.00 mm L X 49.30 mm W X 10.70 mm H body
2284170-3 Connector, Card Edge Right Angle; 49 pin, 77.00 mm L X 49.30 mm W X 10.70 mm H body
2290741-1 Connector, Memory; 31 pin, 28.00 mm L X 18.95 mm W X 1.33 mm H body
2294062 Header, Assembly; 4 pin, 63.50 mm L X 43.10 mm W X 21.05 mm H body
2294415-1 Connector, Right Angle Receptacle; 8 pin, 14.00 mm L X 9.47 mm W X 7.34 mm H body
2295018 Connector, USB Receptacle Right Angle; 24 pin, 9.80 mm L X 7.90 mm W X 3.60 mm H body
2299870-1 Connector, Audio Right Angle; 198 pin, 79.29 mm L X 40.45 mm W X 32.15 mm H body
2301838-1 Connector, DB Vertical Receptacle; 11 pin, 30.78 mm L X 12.55 mm W X 11.95 mm H body
2301844-2 Connector, DB Right Angle Receptacle; 11 pin, 30.81 mm L X 20.65 mm W X 13.955 mm H body
2301996-7 Connector, RJ45 Right Angle; 32 pin, 35.00 mm L X 21.50 mm W X 16.00 mm H body
2301997-7 Connector, RJ45 Right Angle; 32 pin, 28.40 mm L X 17.21 mm W X 26.04 mm H body
2302785-2 Connector, Backplane Right Angle; 116 pin, 28.68 mm L X 22.61 mm W X 14.83 mm H body
2302789-2 Connector, Vertical Receptacle; 144 pin, 29.41 mm L X 18.60 mm W X 11.00 mm H body
2302790-2 Connector, Backplane Vertical; 145 pin, 31.22 mm L X 18.60 mm W X 11.00 mm H body
2305018-2 Connector, USB Receptacle Right Angle; 30 pin, 9.85 mm L X 8.65 mm W X 3.78 mm H body
2309390-1 Connector, Backplane Vertical; 88 pin, 71.628 mm L X 11.938 mm W X 12.827 mm H body
2309409-1 Connector, Socket; 262 pin, 78.00 mm L X 35.50 mm W X 5.35 mm H body
2309409-3 Connector, Socket; 262 pin, 78.00 mm L X 35.50 mm W X 5.35 mm H body
2309410-1 Connector, Memory; 262 pin, 78.00 mm L X 35.50 mm W X 5.35 mm H body
2309411-1 Connector, Right Angle Plug; 262 pin, 78.00 mm L X 35.50 mm W X 8.25 mm H body
2309413-1 Connector, DDR4 SDRAM; 73.00 mm L X 25.85 W X 9.20 mm H
2311768-2 Connector, DB Right Angle Receptacle; 28 pin, 39.14 mm L X 21.80 mm W X 12.80 mm H body
2314578-2 Connector, Backplane Right Angle; 88 pin, 71.628 mm L X 23.622 mm W X 12.70 mm H body
2325864-1 Connector, Right Angle Receptacle; 40 pin, 23.21 mm L X 11.00 mm W X 7.41 mm H body
2327906-2 Connector, Backplane Vertical; 0 pin, 8.50 mm D X 24.00 mm H body
2328702-4 Connector, FFC FPC Right Angle; 6 pin, 4.00 mm L X 3.83 mm W X 1.10 mm H body
2328702-6 Connector, FFC FPC Right Angle; 8 pin, 5.00 mm L X 3.83 mm W X 1.10 mm H body
2328702-8 Connector, FPC Right Angle; 10 pin, 6.00 mm L X 3.83 mm W X 1.10 mm H body
2332816-1 Connector, Backplane Right Angle; 58 pin, 16.08 mm L X 22.61 mm W X 14.83 mm H body
2332817-1 Connector, Backplane Vertical; 73 pin, 16.07 mm L X 18.60 mm W X 11.00 mm H body
2336713-2 Spring finger; 2 pin, 1.70 mm L X 1.10 mm W X 1.55 mm H body
2337019-1 Connector, RF Vertical Receptacle; 3 pin, 2.60 mm L X 2.85 mm W X 1.40 mm H body
234478-E Connector, Right Angle Plug; 16 pin, 20.32 mm L X 7.20 mm W X 3.08 mm H body
2356208-1 Connector, Cage, Right Angle; 208 pin, 59.05 mm L X 71.51 mm W X 14.30 mm H body
2357787-1 Connector, Vertical Board to Board Plug; 222 pin, 61.80 mm L X 6.20 mm W X 4.60 mm H body
2359410-1 Module; 4 pin, 13.92 mm L X 24.46 mm W X 18.44 mm H body
2364030-2 Connector, Backplane Vertical; 145 pin, 31.22 mm L X 18.60 mm W X 11.00 mm H body
2364706-1 Connector, Cage, Right Angle; 309 pin, 87.60 mm L X 71.51 mm W X 16.00 mm H body
2369315-1 Connector, Vertical Receptacle; 444 pin, 62.80 mm L X 18.40 mm W X 4.40 mm H body
2369316-1 Connector, Vertical Plug; 444 pin, 61.90 mm L X 18.40 mm W X 5.90 mm H body
2373109-1 Connector, Card Edge Right Angle; 59 pin, 54.80 mm L X 30.55 mm W X 16.28 mm H body
2374901-1 Connector, Right Angle Plug; 9 pin, 11.00 mm L X 21.90 mm W X 12.85 mm H body
2383938-2 Terminal Block; 2 pin, 10.80 mm L X 8.20 mm W X 10.15 mm H body
2391506-1 Connector, Right Angle Receptacle; 18 pin, 87.06 mm L X 21.415 mm W X 33.40 mm H body
2392896-1 Connector, Vertical Receptacle; 156 pin, 35.70 mm L X 18.50 mm W X 24.50 mm H body
2425753 Switch, Tactile; 2 pin, 3.80 mm L X 1.50 mm W X 0.61 mm H body
2445953-1 Connector, Right Angle Receptacle; 306 pin, 38.20 mm L X 35.80 mm W X 19.35 mm H body
244839-E Connector, Vertical Board to Board Plug; 72 pin, 48.26 mm L X 4.20 mm W X 7.75 mm H body
244855-E Connector, Vertical Board to Board Plug; 30 pin, 21.59 mm L X 4.20 mm W X 8.40 mm H body
2512 Resistor, Chip; 6.35 mm L X 3.15 mm W X 0.80 mm H body
2512 Resistor, Chip; 6.40 mm L X 3.20 mm W X 6.65 mm H body
2512, 6432 Metric Resistor, Chip; 6.35 mm L X 3.15 mm W X 0.84 mm H body
254588-E Connector, Vertical Plug; 24 pin, 17.78 mm L X 4.20 mm W X 6.90 mm H body
280370-1
280370-2
280370-3
280371-1
280371-2
280371-3
280372-1
280372-2
280372-3
280373-1
280373-2
280374-1
Page 45 of 108
