TE Connectivity - Case Codes
2000676-2 Guide Pin; 2 pin, 8.50 mm D X 24.00 mm H body
2007198-1 Connector, Cage; 20 pin, 48.80 mm L X 16.30 mm W X 10.70 mm H body
2007435-1 Connector, HDMI Right Angle; 23 pin, 23.10 mm L X 7.89 mm W X 16.70 mm H body
2007562-6 Connector, Cage Right Angle; 293 pin, 87.35 mm L X 63.60 mm W X 26.49 mm H body
2007825-1 Connector, Backplane Vertical; 193 pin, 36.90 mm L X 20.80 mm W X 24.85 mm H body
2013022-1 Socket; 206 pin, 71.50 mm L X 26.00 mm W X 4.60 mm H body
2013978-1 Connector, HDMI Right Angle; 23 pin, 11.20 mm L X 7.70 mm W X 3.55 mm H body
2013978-2 Connector, HDMI Right Angle; 23 pin, 11.20 mm L X 7.70 mm W X 3.75 mm H body
2029059-2
2029059-4
2029059-6
2029059-8
2029131-2
2029131-4
2029131-6
2029131-8
2029170-2
2029170-4
2029170-6
2029170-8
2029171-2
2029171-4
2029171-6
2029171-8
2029172-2
2029172-4
2029172-6
2029172-8
2029173-2
2029173-4
2029173-6
2029173-8
2029265-2
2029265-4
2029265-6
2029265-8
2040832 Connector, FPC, Edge; 51 pin, 13.00 mm L X 2.00 mm W X 0.20 mm H body
2041021-4 Connector, Right Angle SD Card Reader; 11 pin, 26.60 mm L X 25.00 mm W X 3.30 mm H body
2041051-3
2041051-4
2041119-1 Connector, PCI Express; 54 pin, 29.90 mm L X 8.20 mm W X 4.00 mm H body
2041433-1 Connector, HDMI Right Angle; 23 pin, 15.00 mm L X 13.85 mm W X 2.10 mm H body
2041441-1 Connector, Vertical Receptacle; 20 pin, 17.80 mm L X 6.46 mm W X 16.16 mm H body
2041517 Connector, USB Receptacle Vertical; 5 pin, 7.70 mm L X 3.90 mm W X 10.00 mm H body
2041517-1 Connector, USB Receptacle Vertical; 8 pin, 7.70 mm L X 4.117 mm W X 9.20 mm H body
2057042-1 Housing, Light Pipe; 23 pin, 60.00 mm L X 63.37 mm W X 13.70 mm H body
2057411-1 Connector, Backplane Right Angle; 96 pin, 30.46 mm L X 20.06 mm W X 9.40 mm H body
2069625-1
207441-1
207441-2
207441-7
207441-8
207441-9
2085945-4 Connector, Right Angle Receptacle; 88 pin, 72.16 mm L X 24.20 mm W X 30.10 mm H body
2102736 Connector, Vertical Receptacle; 144 pin, 29.54 mm L X 18.73 mm W X 10.63 mm H body
2106091-1
2106091-1 Connector, Vertical Shrouded Plug; 4 pin, 7.50 mm L X 4.70 mm W X 3.48 mm H body
2106091-2
2106091-3
2106091-4
2110487-1 Connector, Right Angle Receptacle; 12 pin, 58.475 mm L X 20.704 mm W X 9.80 mm H body
2110759-1 Connector, Right Angle Receptacle; 20 pin, 11.10 mm L X 9.45 mm W X 5.40 mm H body
2118718-2 Shield; 20 pin, 26.21 mm L X 26.21 mm W X 5.18 mm H body
2129320-3 Connector, Display Port; 22 pin, 11.40 mm L X 12.65 mm W X 5.52 mm H body
2132230-2
2132230-3
2132230-4
2132230-5
2132230-6
2132230-7
2132230-8
2132230-9
2132415-2
2132415-3
2132415-4
Page 43 of 108
