| 104693-4 |
| 104693-5 |
| 104693-6 |
| 104693-7 |
| 104693-8 |
| 104809-1 |
| 104809-2 |
| 104809-3 |
| 104809-4 |
| 104809-5 |
| 104809-6 |
| 104809-7 |
| 104809-8 |
| 104809-9 |
| 104878-2 |
| 104878-7 |
| 104878-8 |
| 104878-9 |
| 104894-1 |
| 104894-2 |
| 104894-3 |
| 104894-5 |
| 104894-6 |
| 104894-7 |
| 104894-8 |
| 104894-9 |
| 104895-2 |
| 104895-4 |
| 104895-5 |
| 104895-8 |
| 104915-1 |
| 104915-2 |
| 104915-3 |
| 106066-2 |
Connector, RJ45 Right Angle; 10 pin, 16.50 mm L X 19.10 mm W X 13.20 mm H body |
| 1206, 3216 Metric |
Resistor, Chip; 3.05 mm L X 1.55 mm W X 0.65 mm H body |
| 1206SFS |
Fuse, Chip; 3.20 mm L X 1.60 mm W X 1.17 mm H body |
| 120957-2 |
Connector, Right Angle Plug; 28 pin, 24.00 mm L X 22.34 mm W X 9.78 mm H body |
| 1217080-1 |
Connector, Vertical Receptacle; 2 pin, 7.42 mm L X 4.24 mm W X 8.88 mm H body |
| 1217133-1 |
Terminal; 2 pin, 7.92 mm L X 3.11 mm W X 8.89 mm H body |
| 1217167-1 |
Terminal, Quick Connect; 2 pin, 7.92 mm L X 3.08 mm W X 16.25 mm H body |
| 1217861-1 |
Connector; 2 pin, 7.92 mm L X 3.11 mm W X 10.46 mm H body |
| 1218124-1 |
Connector, DB, Plug, Vertical; 9 pin, 30.81 mm L X 12.55 mm W X 12.39 mm H body |
| 1218124-2 |
Connector, DB Vertical Plug; 15 pin, 39.14 mm L X 12.55 mm W X 12.76 mm H body |
| 1218124-3 |
Connector, DB Vertical Plug; 25 pin, 53.035 mm L X 12.55 mm W X 12.92 mm H body |
| 1218124-4 |
Connector, DB Vertical Plug; 37 pin, 69.32 mm L X 12.55 mm W X 12.92 mm H body |
| 1218124-5 |
Connector, DB Vertical Plug; 50 pin, 66.93 mm L X 15.37 mm W X 12.92 mm H body |
| 1218408-1 |
Connector, DB Right Angle Receptacle; 9 pin, 30.81 mm L X 19.235 mm W X 12.93 mm H body |
| 1218408-3 |
Connector, DB Right Angle Receptacle; 25 pin, 53.035 mm L X 19.235 mm W X 12.93 mm H body |
| 1218408-4 |
Connector, DB Right Angle Receptacle; 37 pin, 69.32 mm L X 19.235 mm W X 12.93 mm H body |
| 1218408-5 |
Connector, DB Right Angle Receptacle; 50 pin, 66.93 mm L X 22.025 mm W X 15.75 mm H body |
| 1218444-1 |
Connector, DB Right Angle Plug; 9 pin, 30.81 mm L X 18.995 mm W X 12.93 mm H body |
| 1218444-2 |
Connector, DB Right Angle Plug; 15 pin, 39.14 mm L X 18.995 mm W X 12.93 mm H body |
| 1218444-3 |
Connector, DB Right Angle Plug; 25 pin, 52.885 mm L X 21.915 mm W X 12.93 mm H body |
| 1218444-4 |
Connector, DB Right Angle Plug; 37 pin, 69.32 mm L X 18.995 mm W X 12.93 mm H body |
| 1218444-5 |
Connector, DB Right Angle Plug; 50 pin, 66.93 mm L X 21.915 mm W X 15.75 mm H body |
| 1241050-5 |
Header, Vertical Plug; 10 pin, 12.70 mm L X 5.00 mm W X 9.90 mm H body |
| 1241050-6 |
| 1241050-7 |
| 1241050-8 |
| 1241150-4 |
| 1241150-6 |
| 1241150-7 |
| 1241150-8 |
| 1241150-9 |
| 1241152-6 |
Connector, Vertical Receptacle; 6 pin, 15.50 mm L X 2.52 mm W X 6.20 mm H body |
| 1274571-1 |
Connector, DC Power Jack Vertical; 5 pin, 7.54 mm L X 9.02 mm W X 11.58 mm H body |
| 1318164-1 |
Battery Holder; 2 pin, 9.60 mm L X 6.70 mm W X 2.40 mm H body |
| 1318384-2 |
Connector, Right Angle Shrouded Plug; 40 pin, 49.40 mm L X 18.40 mm W X 15.80 mm H body |
| 1367073-1 |
Connector, SFP, Vertical; 22 pin, 11.20 mm L X 7.70 mm W X 5.40 mm H body |
| 1367073-2 |
| 1367073-3 |
| 1367073-4 |
| 1367073-6 |
| 1375549-1 |
| 1375549-2 |
