Transistor, Small Outline Flat Lead (SOFL), 1.27 mm pitch; 6 pin, 3.81 mm L X 3.81 mm W X 4.06 mm H body |
12-VQFN |
Quad Flat No-Lead (QFN) with tab, 0.51 mm pitch; 13 pin, square, 3 pin X 3 pin, 3.00 mm L X 3.00 mm W X 0.99 mm H body |
1206, 3216 Metric |
Filter; 4 pin, 3.20 mm L X 1.60 mm W X 0.94 mm H body |
ADTT1-1 |
Transformer; 6 pin, 7.87 mm L X 5.59 mm W X 2.84 mm H body |
AH202-1 |
Coupler; 8 pin, 12.70 mm L X 9.65 mm W X 6.35 mm H body |
AH202-1 |
Splitter and Combiner; 8 pin, 12.70 mm L X 9.65 mm W X 6.35 mm H body |
AT1029 |
Splitter and Combiner; 5 pin, 4.22 mm L X 3.81 mm W X 3.94 mm H body |
AT1521 |
RF Transformer; 5 pin, 3.81 mm L X 3.81 mm W X 4.06 mm H body |
AT1642 |
Directional Coupler; 5 pin, 4.22 mm L X 3.81 mm W X 3.94 mm H body |
AT1667 |
Pullback Small Outline No-Lead (PSON); 5 pin, 3.81 mm L X 3.81 mm W X 3.91 mm H body |
AT1667-1 |
Directional Coupler; 5 pin, 3.81 mm L X 3.81 mm W X 3.81 mm H body |
AT224-1 |
RF Transformer; 5 pin, 3.96 mm L X 3.96 mm W X 4.06 mm H body |
AT224-1A |
AT224-2 |
RF Transformer; 6 pin, 3.96 mm L X 3.96 mm W X 4.06 mm H body |
CASE GU1604 |
Filter, Dual Flat No-Lead (DFN 4 Pins), 2.54 mm pitch; 4 pin, 3.81 mm L X 3.81 mm W X 3.81 mm H body |
CBP-1023A+ |
Resonator; 17 pin, 26.24 mm L X 13.97 mm W X 5.87 mm H body |
CD542 |
Small Outline IC (SOIC), 2.54 mm pitch; 6 pin, 7.87 mm L X 5.58 mm W X 2.84 mm H body |
CD542 |
Small Outline IC (SOIC), 2.54 mm pitch; 6 pin, 7.87 mm L X 5.59 mm W X 2.84 mm H body |
CD542 |
CD636 |
Small Outline IC (SOIC), 2.54 mm pitch; 6 pin, 7.87 mm L X 5.59 mm W X 4.11 mm H body |
CD637 |
Small Outline Flat Lead (SOFL), 2.54 mm pitch; 6 pin, 7.87 mm L X 5.59 mm W X 1.40 mm H body |
CJ725 |
Small Outline IC (SOIC), 2.54 mm pitch; 8 pin, 10.415 mm L X 7.87 mm W X 5.46 mm H body |
CK1113 |
CK1246-1 |
Limiter; 16 pin, 12.70 mm L X 12.70 mm W X 4.62 mm H body |
CK605 |
Module; 16 pin, 12.70 mm L X 12.70 mm W X 4.572 mm H body |
CK605 |
Voltage Controlled Oscillator (VCO); 16 pin, 12.90 mm L X 12.90 mm W X 4.67 mm H body |
DB1627 |
Directional Coupler; 6 pin, 3.81 mm L X 4.06 mm W X 4.06 mm H body |
DB1627 |
DB1627 |
Small Outline Flat Lead (SOFL); 6 pin, 3.81 mm L X 3.81 mm W X 4.06 mm H body |
DB1627 |
Transformer, Small Outline Flat Lead (SOFL), 1.27 mm pitch; 6 pin, 3.81 mm L X 3.06 mm W X 4.06 mm H body |
DB1627 |
Transformer; 6 pin, 3.81 mm L X 3.81 mm W X 4.06 mm H body |
DB714 |
Transformer; 6 pin, 4.06 mm L X 3.81 mm W X 4.06 mm H body |
DF782 |
DF782 |
Amplifier; 3 pin, 2.59 mm L X 4.60 mm W X 1.60 mm H body |
DF782 |
Amplifier; 3 pin, 4.495 mm L X 2.44 mm W X 1.60 mm H body |
DG1677-2 |
Quad Flat No-Lead (QFN) with tab, 33 pin, 5.00 mm L X 5.00 mm W X 0.99 mm H body |
DG1847 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; 25 pin, square, 6 pin X 6 pin, 4.00 mm L X 4.00 mm W X 1.00 mm H body |
DG1847 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 6 pin X 6 pin, 4.00 mm L X 4.00 mm W X 1.00 mm H body |
DG983-2 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 5 pin X 5 pin, 4.00 mm L X 4.00 mm W X 0.977 mm H body |
DL1636 |
Small Outline No-Lead (SON) with tab, 1.27 mm pitch; 9 pin, 4.90 mm L X 6.00 mm W X 1.06 mm H body |
DL1636 |
Small Outline No-Lead (SON) with tab, 9 pin, 4.90 mm L X 6.00 mm W X 1.00 mm H body |
DLFCG-540+ |
Inductor, Chip Array, 2-Sided Concave, 0.66 mm pitch; 6 pin, 2.01 mm L X 1.24 mm W X 0.889 mm H body |
DQ1225 |
Quad Flat No-Lead (QFN) with tab, 0.508 mm pitch; square, 3 pin X 3 pin, 2.997 mm L X 2.997 mm W X 0.991 mm H body |
DQ1225 |
Quad Flat No-Lead (QFN) with tab, 0.51 mm pitch; square, 3 pin X 3 pin, 3.00 mm L X 3.00 mm W X 0.89 mm H body |
DQ1225 |
Quad Flat No-Lead (QFN) with tab, 0.51 mm pitch; square, 3 pin X 3 pin, 3.00 mm L X 3.00 mm W X 0.94 mm H body |
DQ1225 |
Quad Flat No-Lead (QFN) with tab, 0.51 mm pitch; square, 3 pin X 3 pin, 3.00 mm L X 3.00 mm W X 0.99 mm H body |
DQ1225 |
Quad Flat No-Lead (QFN) with tab, 0.51 mm pitch; square, 3 pin X 3 pin, 3.00 mm L X 3.00 mm W X 0.992 mm H body |
DQ849 |
Quad Flat No-Lead (QFN) with tab, 0.66 mm pitch; square, 2 pin X 2 pin, 3.00 mm L X 3.00 mm W X 0.99 mm H body |
DZ1650 |
Integrated Circuit; 10 pin, 7.62 mm L X 6.35 mm W X 1.57 mm H body |
FG873 |
FG873 |
Antenna; 4 pin, 4.24 mm L X 4.24 mm W X 0.94 mm H body |
FV1206 |
FV1206 |
Filter; 4 pin, 3.20 mm L X 1.60 mm W X 0.99 mm H body |
FV1206-1 |
Chip Array, 2 Side Flat, 0.99 mm pitch; 6 pin, 3.20 mm L X 1.60 mm W X 0.897 mm H body |
FV1206-1 |
Chip Array, 2 Side Flat, 0.99 mm pitch; 6 pin, 3.20 mm L X 1.60 mm W X 1.07 mm H body |
FV1206-1 |
Chip Array, 2 Side Flat, 0.99 mm pitch; 6 pin, 3.201 mm L X 1.601 mm W X 1.067 mm H body |
FV1206-1 |
Chip Array, 2 Side Flat, 1.00 mm pitch; 6 pin, 3.60 mm L X 1.60 mm W X 1.08 mm H body |
FV1206-1 |
Filter; 6 pin, 3.20 mm L X 1.60 mm W X 0.89 mm H body |
FV1206-1 |
Filter; 6 pin, 3.20 mm L X 1.60 mm W X 1.068 mm H body |
FV1206-1 |
Power Spliter, 2 Side Concave, 0.99 mm pitch; 6 pin, 3.25 mm L X 1.65 mm W X 0.96 mm H body |
FV1206-4 |
FV1206-4 |
Filter; 4 pin, 3.20 mm L X 1.60 mm W X 1.04 mm H body |
FV1206-6 |
Filter; 8 pin, 3.20 mm L X 1.60 mm W X 1.041 mm H body |
GE0805C-1 |
Chip Array, 2 Side Flat, 0.66 mm pitch; 6 pin, 2.007 mm L X 1.245 mm W X 1.069 mm H body |
GE0805C-10 |
Chip Array, 2 Side Flat, 0.66 mm pitch; 6 pin, 2.01 mm L X 1.24 mm W X 0.612 mm H body |
GE0805C-2 |
Chip Array, 4 Side Flat, 0.65 mm pitch; 8 pin, 2.01 mm L X 1.25 mm W X 0.95 mm H body |
GE0805C-2 |
Filter, 4 Side Concave, 0.65 mm pitch; 8 pin, 2.05 mm L X 1.30 mm W X 0.95 mm H body |
GE0805C-2 |
Filter; 8 pin, 2.00 mm L X 1.25 mm W X 0.95 mm H body |
GE0805C-2 |
Filter; 8 pin, 2.00 mm L X 1.25 mm W X 1.077 mm H body |
GE0805C-3 |
Filter; 4 pin, 2.007 mm L X 1.245 mm W X 1.041 mm H body |
GE0805C-9 |
Transformer; 6 pin, 2.00 mm L X 1.24 mm W X 1.069 mm H body |
GP731 |
Filter; 8 pin, 8.89 mm L X 8.89 mm W X 2.59 mm H body |
GP731 |
Filter; 8 pin, 8.89 mm L X 8.89 mm W X 2.591 mm H body |
GU1414 |
Filter; 5 pin, 3.81 mm L X 3.81 mm W X 3.66 mm H body |
HF1139 |
Filter; 8 pin, 18.80 mm L X 11.18 mm W X 7.01 mm H body |
