| 05-08-1707 DHD16 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 17 pin, 5.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1707 DHD17 |
| 05-08-1708 DE14 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 15 pin, 4.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1709 DH16 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 17 pin, 5.00 mm L X 5.00 mm W X 0.80 mm H body |
| 05-08-1710 UF20 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 5 pin X 5 pin, 4.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1711 UFD20 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 6 pin X 4 pin, 5.00 mm L X 4.00 mm W X 0.75 mm H body |
| 05-08-1711 UFD20 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 6 pin X 4 pin, 5.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1712 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 8 pin X 6 pin, 5.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1712 UFD28 |
| 05-08-1714 DJC22 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 22 pin, 6.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1715 DCB6 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 7 pin, 2.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1717 DC3 |
Dual Flat No-Lead (DFN 3 Pins); 4 pin, 2.00 mm L X 2.00 mm W X 0.80 mm H body |
| 05-08-1718 DCB8 |
Small Outline No-Lead (SON) with tab, 0.45 mm pitch; 9 pin, 2.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1719 DC8 |
Small Outline No-Lead (SON) with tab, 0.45 mm pitch; 9 pin, 2.00 mm L X 2.00 mm W X 0.80 mm H body |
| 05-08-1720 UD20 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; square, 5 pin X 5 pin, 3.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1721 UF28 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; square, 7 pin X 7 pin, 4.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1722 DDB10 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 11 pin, 3.00 mm L X 2.00 mm W X 0.80 mm H body |
| 05-08-1722 DFN-10 |
| 05-08-1723 DDB12 |
Small Outline No-Lead (SON) with tab, 0.45 mm pitch; 13 pin, 3.00 mm L X 2.00 mm W X 0.80 mm H body |
| 05-08-1724 DC4 |
Dual Flat No-Lead (DFN 4 Pins); 5 pin, 2.00 mm L X 2.00 mm W X 0.80 mm H body |
| 05-08-1725 DD12 |
Small Outline No-Lead (SON) with tab, 0.45 mm pitch; 13 pin, 3.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1725 DFN12 |
| 05-08-1727 UHH56 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; rect., 18 pin X 10 pin, 9.00 mm L X 5.00 mm W X 0.80 mm H body |
| 05-08-1728 UJ40 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 10 pin X 10 pin, 6.00 mm L X 6.00 mm W X 0.80 mm H body |
| 05-08-1729 UKG52 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 14 pin X 12 pin, 8.00 mm L X 7.00 mm W X 0.80 mm H body |
| 05-08-1731 DE14MA |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 14 pin, 4.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1732 DE16 |
Small Outline No-Lead (SON) with tab, 0.45 mm pitch; 17 pin, 4.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1733 DF12 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 13 pin, 4.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1734 DKD32 |
Small Outline No-Lead (SON) with tab, 0.40 mm pitch; 33 pin, 7.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1735 LU32 |
Quad Flat Pack (QFP), 0.50 mm pitch; square, 8 pin X 8 pin, 5.00 mm L X 5.00 mm W X 1.20 mm H body |
| 05-08-1738 PD16 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 4 pin X 4 pin, 3.00 mm L X 3.00 mm W X 0.60 mm H body |
| 05-08-1739 KD10 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 11 pin, 3.00 mm L X 3.00 mm W X 0.60 mm H body |
| 05-08-1741 UKH64 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; rect., 19 pin X 13 pin, 9.00 mm L X 7.00 mm W X 0.80 mm H body |
| 05-08-1742 QFN20 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 6 pin X 4 pin, 4.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1742 UDC20 |
| 05-08-1742 UDC20 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 16 pin, 6.50 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1745 UDC24 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; rect., 7 pin X 5 pin, 4.00 mm L X 3.00 mm W X 0.80 mm H body |
| 05-08-1746 UH40 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; square, 10 pin X 10 pin, 5.00 mm L X 5.00 mm W X 0.80 mm H body |
| 05-08-1747 QFN24 |
Quad Flat No-Lead (QFN) with tab, 0.65 mm pitch; square, 6 pin X 6 pin, 5.00 mm L X 5.00 mm W X 0.60 mm H body |
| 05-08-1747 UH24 |
Quad Flat No-Lead (QFN) with tab, 0.65 mm pitch; square, 6 pin X 6 pin, 5.00 mm L X 5.00 mm W X 0.80 mm H body |
| 05-08-1748 PF24 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 6 pin X 6 pin, 4.00 mm L X 4.00 mm W X 0.60 mm H body |
| 05-08-1748 PF24 |
Quad Flat No-Lead (QFN) with tab, 26 pin, 4.00 mm L X 4.00 mm W X 0.60 mm H body |
| 05-08-1749 KC8 |
Small Outline No-Lead (SON) with tab, 0.45 mm pitch; 9 pin, 2.00 mm L X 2.00 mm W X 0.60 mm H body |
| 05-08-1750 HFE38 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; rect., 12 pin X 7 pin, 6.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1750 UFE38 |
| 05-08-1751 KE14 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 15 pin, 4.00 mm L X 3.00 mm W X 0.60 mm H body |
| 05-08-1752 PDC20 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; rect., 6 pin X 4 pin, 4.00 mm L X 3.00 mm W X 0.60 mm H body |
| 05-08-1754 G44 |
Small Outline Pkg (SOP), 0.50 mm pitch; 44 pin, 12.80 mm L X 5.30 mm W X 2.00 mm H body |
| 05-08-1756 LGA113 |
Land Grid Array (LGA), 1.27 mm pitch, square; 113 pin, 15.00 mm L X 15.00 mm W X 4.42 mm H body |
| 05-08-1757 LGA108 |
Land Grid Array (LGA), 1.27 mm pitch, rect.; 108 pin, 15.00 mm L X 11.25 mm W X 2.42 mm H body |
| 05-08-1758 |
Quad Flat No-Lead (QFN) with tab, 35 pin, 7.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1759 PF28 |
Quad Flat No-Lead (QFN) with tab, 0.40 mm pitch; square, 7 pin X 7 pin, 4.00 mm L X 4.00 mm W X 0.60 mm H body |
| 05-08-1760 LX48 |
Ceramic Quad Flat Pack (CQFP), 0.50 mm pitch; square, 12 pin X 12 pin, 7.00 mm L X 7.00 mm W X 1.60 mm H body |
| 05-08-1760 LX48 |
Quad Flat Pack (QFP), 0.50 mm pitch; square, 12 pin X 12 pin, 7.00 mm L X 7.00 mm W X 1.20 mm H body |
| 05-08-1760 LX48 |
Quad Flat Pack (QFP), 0.50 mm pitch; square, 12 pin X 12 pin, 7.00 mm L X 7.00 mm W X 1.60 mm H body |
| 05-08-1763 UK44 |
Quad Flat No-Lead (QFN) with tab, 0.50 mm pitch; square, 11 pin X 11 pin, 7.00 mm L X 7.00 mm W X 0.80 mm H body |
| 05-08-1766 LGA133 |
Land Grid Array (LGA), 1.27 mm pitch, square; 133 pin, 15.00 mm L X 15.00 mm W X 2.92 mm H body |
| 05-08-1770 UFE-26 |
Quad Flat No-Lead (QFN) with tab, 28 pin, 6.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1771 FE24 |
Small Outline Pkg (SOP) with tab, 0.65 mm pitch; 25 pin, 7.80 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1772 FE38 |
Small Outline Pkg (SOP) with tab, 0.50 mm pitch; 39 pin, 9.70 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1772 FE38 |
Small Outline Pkg (SOP) with tab, 0.50 mm pitch; 40 pin, 9.70 mm L X 4.40 mm W X 1.20 mm H body |
| 05-08-1773 LGA32 |
Land Grid Array (LGA), 1.27 mm pitch, rect.; 32 pin, 15.00 mm L X 11.25 mm W X 2.95 mm H body |
| 05-08-1775 LGA121 |
Land Grid Array (LGA), 1.27 mm pitch, square; 121 pin, 15.00 mm L X 15.00 mm W X 2.97 mm H body |
| 05-08-1777 LGA133 |
Land Grid Array (LGA), 1.27 mm pitch, square; 133 pin, 15.00 mm L X 15.00 mm W X 4.42 mm H body |
| 05-08-1778 DHD18 |
Small Outline No-Lead (SON) with tab, 0.50 mm pitch; 19 pin, 5.00 mm L X 4.00 mm W X 0.80 mm H body |
| 05-08-1800 LGA104 |
Land Grid Array (LGA); 104 pin, 15.00 mm L X 15.00 mm W X 2.92 mm H body |
| 05-08-1801 LGA118 |
Land Grid Array (LGA), 1.27 mm pitch, square; 118 pin, 15.00 mm L X 15.00 mm W X 2.92 mm H body |
| 05-08-1803 LGA21 |
Land Grid Array (LGA), 1.27 mm pitch, square; 21 pin, 6.25 mm L X 6.25 mm W X 2.42 mm H body |
| 05-08-1804 LGA50 |
Land Grid Array (LGA), 1.27 mm pitch, rect.; 50 pin, 11.25 mm L X 9.00 mm W X 2.92 mm H body |
| 05-08-1805 LGA35 |
Land Grid Array (LGA), 1.27 mm pitch, rect.; 35 pin, 11.25 mm L X 6.25 mm W X 2.92 mm H body |
| 05-08-1807 LGA66 |
Land Grid Array (LGA), 1.27 mm pitch, rect.; 66 pin, 15.00 mm L X 9.00 mm W X 2.45 mm H body |
| 05-08-1808 LGA68 |
Land Grid Array (LGA), 1.27 mm pitch, rect.; 68 pin, 15.00 mm L X 9.00 mm W X 2.95 mm H body |
| 05-08-1809 LGA81 |
Land Grid Array (LGA), 1.27 mm pitch, square; 81 pin, 11.25 mm L X 11.25 mm W X 2.47 mm H body |
| 05-08-1810 LGA66 |
Land Grid Array (LGA), 1.27 mm pitch, rect.; 66 pin, 15.00 mm L X 9.00 mm W X 4.42 mm H body |
| 05-08-1815 LGA141 |
Land Grid Array (LGA), 1.27 mm pitch, square; 141 pin, 15.00 mm L X 15.00 mm W X 2.92 mm H body (w/reversed pins) |
