API Delevan - Case Codes
DC780-333K Inductor, Radial (Inductor); 13.868 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-334K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-392L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-393K Inductor, Radial (Inductor); 15.088 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-394K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-472L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-473K Inductor, Radial (Inductor); 15.875 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-474K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-562L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-563K Inductor, Radial (Inductor); 15.875 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-564K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-682L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-683K Inductor, Radial (Inductor); 16.662 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-684K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-822L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-823K Inductor, Radial (Inductor); 16.662 mm C X 20.20 mm Dia X 21.10 mm H body
DC780-824K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-102L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-103K Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-104K Inductor, Radial (Inductor); 15.062 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-105K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-122L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-123K Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-124K Inductor, Radial (Inductor); 15.062 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-125K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-152L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-153K Inductor, Radial (Inductor); 15.875 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-154K Inductor, Radial (Inductor); 15.062 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-155K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-182L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-183K Inductor, Radial (Inductor); 16.002 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-184K Inductor, Radial (Inductor); 15.062 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-185K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-222L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-223K Inductor, Radial (Inductor); 16.002 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-224K Inductor, Radial (Inductor); 15.062 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-225K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-272L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-273K Inductor, Radial (Inductor); 13.868 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-274K Inductor, Radial (Inductor); 14.275 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-332L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-333K Inductor, Radial (Inductor); 13.868 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-334K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-392L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-393K Inductor, Radial (Inductor); 15.088 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-394K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-472L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-473K Inductor, Radial (Inductor); 15.875 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-474K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-562L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-563K Inductor, Radial (Inductor); 15.875 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-564K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-682L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-683K Inductor, Radial (Inductor); 16.662 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-684K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-822L Inductor, Radial (Inductor); 15.748 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-823K Inductor, Radial (Inductor); 16.662 mm C X 20.20 mm Dia X 21.10 mm H body
DC780R-824K Inductor, Radial (Inductor); 14.986 mm C X 20.20 mm Dia X 21.10 mm H body
EMI 1812 Ferrite Bead, Chip; 4.50 mm L X 3.20 mm W X 1.75 mm H body
EMI-0805 Ferrite Bead, Chip; 4.50 mm L X 3.20 mm W X 1.75 mm H body
EMI0603R Ferrite Bead, Chip; 1.60 mm L X 0.80 mm W X 0.95 mm H body
EMI0805R Ferrite Bead, Chip; 2.00 mm L X 1.25 mm W X 1.10 mm H body
EMI1206R Ferrite Bead, Chip; 3.20 mm L X 1.60 mm W X 1.30 mm H body
EMI1806R Ferrite Bead, Chip; 4.50 mm L X 1.60 mm W X 1.80 mm H body
EMI1812R Ferrite Bead, Chip; 4.50 mm L X 3.20 mm W X 1.75 mm H body
ER1025 Inductor, Axial; 10.00 mm C X 0.51 mm W 6.60 mm L X 2.66 mm Dia body
ER1537 Inductor, Axial; 15.00 mm C X 0.635 mm W 9.78 mm L X 4.21 mm Dia body
ER1641 Inductor, Axial; 16.00 mm C X 0.635 mm W 10.92 mm L X 4.36 mm Dia body
ER1840 Inductor, Axial; 16.00 mm C X 0.635 mm W 11.35 mm L X 5.00 mm Dia body
HF1008 Inductor, Molded Body; 1.905 mm L X 2.41 mm W X 2.41 mm H body
HF1008R Inductor, Molded Body; 1.905 mm L X 2.41 mm W X 2.41 mm H body
HTPT66-103K Inductor, Fixed; 2 pin, 9.14 mm L X 16.76 mm W X 16.76 mm H body
HTPT66-122K Inductor, Fixed; 2 pin, 9.14 mm L X 16.76 mm W X 16.76 mm H body
HTPT66-152K Inductor, Fixed; 2 pin, 9.14 mm L X 16.76 mm W X 16.76 mm H body
HTPT66-153K Inductor, Fixed; 2 pin, 9.14 mm L X 16.76 mm W X 16.76 mm H body
Page 6 of 7
