| 5142 |
			Inductor; 2 pin, 13.84 mm L X 10.92 mm W X 4.70 mm H body |
			| 5500 |
			Inductor, Molded Body; 24.38 mm L X 12.58 mm W X 13.12 mm H body |
			| 5500R |
			| 5526 |
			Inductor; 2 pin, 10.67 mm L X 6.35 mm W X 5.97 mm H body |
			| 5526R |
			| 603 |
			Inductor; 2 pin, 1.80 mm L X 1.14 mm W X 1.02 mm H body |
			| 805 |
			Inductor; 2 pin, 2.29 mm L X 1.73 mm W X 1.52 mm H body |
			| 819 |
			Inductor, Axial; 9.00 mm C X 0.508 mm W 5.33 mm L X 2.18 mm Dia body |
			| 8532 |
			Inductor, Molded Body; 20.33 mm L X 8.125 mm W X 7.26 mm H body |
			| 8532R |
			| 925 |
			Inductor, Axial; 10.00 mm C X 0.508 mm W 6.60 mm L X 2.66 mm Dia body |
			| 9405 |
			Coil; 2 pin, 9.65 mm D X 12.70 mm H body |
			| 9405R |
			| 9406 |
			Inductor; 4 pin, 12.70 mm L X 9.53 mm W X 9.53 mm H body |
			| 9406R |
			| CM1011 |
			Choke, Common Mode; 4 pin, 27.90 mm L X 27.90 mm W X 18.56 mm H body |
			| CM1011R |
			| CM6149 |
			CommonMode Choke; 4 pin, 7.24 mm L X 6.35 mm W X 5.33 mm H body |
			| CM6149R |
			Choke, Common Mode; 4 pin, 7.49 mm D X 5.33 mm H body |
			| CM6296 |
			Choke, Common Mode; 4 pin, 26870 u D X 10740 u H body |
			| CM6296R |
			| CM6350 |
			Choke, Common Mode; 4 pin, 9.14 mm L X 8.90 mm W X 5.33 mm H body |
			| CM6350R |
			CommonMode Choke; 4 pin, 9.39 mm D X 5.33 mm H body |
			| CM6460 |
			Choke, Common Mode; 4 pin, 14.351 mm L X 14.351 mm W X 7.62 mm H body |
			| CM6460R |
			Choke, Common Mode; 4 pin, 13.71 mm D X 7.62 mm H body |
			| CM6560 |
			Choke, Common Mode; 4 pin, 17.78 mm L X 17.78 mm W X 8.509 mm H body |
			| CM6560R |
			| CM6594 |
			Transformer; 8 pin, 9.91 mm L X 10.80 mm W X 5.97 mm H body |
			| CM6594R |
			| CM7560 |
			Choke, Common Mode; 4 pin, 27.20 mm L X 21.80 mm W X 21.86 mm H body |
			| CM7560R |
			| CM9900 |
			Choke, Common Mode; 4 pin, 21.30 mm L X 18.80 mm W X 17.00 mm H body |
			| CM9900R-4TERMINAL |
			| DC1050-104K |
			Inductor, Radial (Inductor); 20.75 mm C X 29.98 mm Dia X 21.34 mm H body |
			| DC1050-105K |
			Inductor, Radial (Inductor); 19.56 mm C X 29.98 mm Dia X 21.34 mm H body |
			| DC1050-124K |
			| DC1050-125K |
			| DC1050-154K |
			| DC1050-155K |
			| DC1050-185K |
			| DC1050-224K |
			| DC1050-225K |
			| DC1050-274K |
			| DC1050-275K |
			| DC1050-334K |
			| DC1050-335K |
			| DC1050-394K |
			| DC1050-395K |
			| DC1050-474K |
			| DC1050-475K |
			| DC1050-564K |
			| DC1050-684K |
			| DC1050-824K |
			| DC1050K184K |
			| DC1050R-104K |
			| DC1050R-105K |
			| DC1050R-124K |
			| DC1050R-125K |
			| DC1050R-154K |
			| DC1050R-155K |
			| DC1050R-184K |
			| DC1050R-185K |
			| DC1050R-224K |
			| DC1050R-225K |
			| DC1050R-274K |
			| DC1050R-275K |
			| DC1050R-334K |
			| DC1050R-335K |
			| DC1050R-394K |
			| DC1050R-395K |
			| DC1050R-474K |
			| DC1050R-475K |
			| DC1050R-564K |
			| DC1050R-684K |
			| DC1050R-824K |
