LT1375IS8#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1375IS8-5 IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1375IS8-5#PBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1375IS8-5#TR IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1375IS8-5#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8 IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8#PBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8#TR IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8-5 IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8-5#PBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8-5#TR IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376CS8-5#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVCS8 IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVCS8#PBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVCS8#TR IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVCS8#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVIS8 IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVIS8#PBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVIS8#TR IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376HVIS8#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8 IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8#PBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8#TR IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8-5 IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8-5#PBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8-5#TR IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1376IS8-5#TRPBF IC, 1.5A, 500KHz Step-Down Switching Regulator
LT1377CS8 IC, 500KHz and 1 MHz High Efficiency 1.5A Switching Regulator
LT1377CS8#PBF IC, 500KHz and 1 MHz High Efficiency 1.5A Switching Regulator
LT1377CS8#TR IC, 500KHz and 1 MHz High Efficiency 1.5A Switching Regulator
LT1377CS8#TRPBF IC, 500KHz and 1 MHz High Efficiency 1.5A Switching Regulator
LT1377IS8 IC, 500KHz and 1 MHz High Efficiency 1.5A Switching Regulator
LT1377IS8#PBF IC, 500KHz and 1 MHz High Efficiency 1.5A Switching Regulator
LT1377IS8#TR IC, 500KHz and 1 MHz High Efficiency 1.5A Switching Regulator
LT1389ACS8-1.25 IC, Nanopower Precision Shunt Voltage Reference
LT1389ACS8-1.25#PBF IC, Nanopower Precision Shunt Voltage Reference
LT1389ACS8-1.25#TR IC, Nanopower Precision Shunt Voltage Reference
LT1389ACS8-1.25#TRPBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-1.25 IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-1.25#PBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-1.25#TR IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-1.25#TRPBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-2.5 IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-2.5#PBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-2.5#TR IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-2.5#TRPBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-4.096 IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-4.096#PBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-4.096#TR IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-4.096#TRPBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-5 IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-5#PBF IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-5#TR IC, Nanopower Precision Shunt Voltage Reference
LT1389BCS8-5#TRPBF IC, Nanopower Precision Shunt Voltage Reference
LT1394CS8 IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1394CS8#PBF IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1394CS8#TR IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1394CS8#TRPBF IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1394IS8 IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1394IS8#PBF IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1394IS8#TR IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1394IS8#TRPBF IC, 7ns, Low Power, Single Supply, Ground-Sensing Comparator
LT1395CS8 IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1395CS8#PBF IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1395CS8#TR IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1395CS8#TRPBF IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1396CS8 IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1396CS8#PBF IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1396CS8#TR IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1396CS8#TRPBF IC, Single/Dual/Quad 400 MHz Current Feedback Amplifier
LT1413S8 IC, Single Supply, Dual Precision Op Amp
LT1413S8#PBF IC, Single Supply, Dual Precision Op Amp
LT1413S8#TR IC, Single Supply, Dual Precision Op Amp
Page 16 of 58
