Wirebound inductor
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: Wirebound inductor
    Posted: 03 Mar 2021 at 5:55am
Hi to all:
I am trying to create a footprint of a wirebound inductor, Murata LQW18AN5N6G80D.
I configured my component as an SMD/Chip/Inductor and as the metalization of the pin part is not the height of the component, I configured the height of the part as the height of the metalization.
How do you resolve that kind of components?
Thanks for your comments.
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 9:53am
These Inductors are becoming more popular these days. There should be a mfr. recommended pattern for the footprint. If not, the pad size is:
Heel = 0.00 but you need to compensate for the +/- body length tolerance of 0.10
Side = 50% of the metal thickness height up the side (Maximum)
Toe = 100% of the metal thickness height up the side (Maximum)
So the pad size for this part is 0.56 L X 1.20 W. Add 0.05 for the Heel to compensate for the tolerance.
Here's a SolidWorks 3D model:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 12:17am
Hi Tom:
Yes you are right . We are using more and more this kind of components in our designs.
Many thanks for your recommendations.
Regards.
David
IMI4tth3w View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IMI4tth3w Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 8:53am
I actually just did a footprint for one of these types of inductors.
Coilcraft seems to have pretty good guidelines for footprints in their datasheets.
Here's an example:
https://www.coilcraft.com/en-us/products/rf/ferrite-core-chip-inductors/0603-(1608)/0603ls/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 9:06am
Continue to use the mfr. recommended pattern for this new package style and new terminal lead form.
Automating a software program to calculate the pad stack would need to identify a new terminal lead form and then the solder joint goal table for a 3-Tier density level.
It's too late to put it in IPC-7351C and it's not in IPC-J-STD-001 yet for assembly solder joint acceptability.
Jeromeli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeromeli Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 5:55am
I have encountered a similar problem recently, and I am trying to solve it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2022 at 10:46am
You must use the Manufacturer's Recommended Pattern.
pem3bg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pem3bg Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 6:36am
Hi all,
I'm trying to create footprint for an inductor like on the next picture:
What would be the best type to use for this inductor (Chip Inductor or DFN 2 pins  Inductor).
I'm asking this because I want to have IPC name for this footprint and when I create footprint with both types I got different name. So what would be the best solution for this.
It's Murata LQH44PN150MPRL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 7:36am
This Murata LQH44PN150MPRL have a trapezoid pad shape.
It cannot be created in Footprint Expert, but we can build it in a CAD tool and export/import the ASCII file into FPX format.
This page was generated in 0.218 seconds.
