Forum Home Forum Home > Libraries > Footprints / Land Patterns > OrCAD Layout
    Posted: 31 Jul 2024 at 3:57am
Footprint Expert
Source 1
Source 2
Inconsistent and extra markings and excessive courtyards requires more placement space
The Footprint Expert automates footprints to perfection. Professional, detailed, and accurate parts – all built consistently with identical rules, regardless of how many people are involved in your library development. Contact us for more samples, details, demo, or evaluation license!
