  New Posts New Posts RSS Feed - Export to Diptrace
Export to Diptrace
dwaltoneng View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwaltoneng Quote  Post ReplyReply Direct Link To This Post Topic: Export to Diptrace
    Posted: 25 Mar 2013 at 3:16am
Not all pads in a component are transferred to a Diptrace component.
If I select a QFN part (eg PQFN50P500X500X40-33) and click on "Build Selection" to create a library and import this into the Diptrace Pattern Editor, I only get the top and bottom rows of pads. The pads on the sides and the thermal pad are not imported.
I have just used the defaults when building the library. I have tried building to other PADS formats, but this did not change anything noticeable.
I am using version 2.3.1.0 of Diptrace.
Does anyone have any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwaltoneng Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2013 at 2:52pm
This turned out to be a bug in DipTrace.
See here http://www.diptrace.com/forum/viewtopic.php?f=5&t=9060&p=13765#p13765
Also only PADS ASCII import from 2005 and 2007 has been tested with DipTrace.
andy123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andy123 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 2:42am
I would like to thank you for sharing such a great info with us
This page was generated in 1.514 seconds.
