Forum Home Forum Home > Libraries > Footprints / Land Patterns > CADSTAR
  New Posts New Posts RSS Feed - Inductor Footprints Requiring C shaped Pads
PlanoDoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PlanoDoug Quote  Post ReplyReply Direct Link To This Post Topic: Inductor Footprints Requiring C shaped Pads
    Posted: 11 Feb 2013 at 9:21am
I notice more and more small SMT inductors data sheets asking for C shaped pads.
I would prefer to use rectangular pads even though Cadstar if not PCB Libraries and IPC standard can indeed support Polygon Pads.
Is there any unanticipated problem I am going to encounter by replacing the two C shapes as called out in the data sheet with Rectangles?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 9:31am
Can you please post a web-link to a component package datasheet that has "C-shape" leads or a mfr. recommended pattern the calls for "C-shape" pads?
We would really appreciate it and it's the only way we can support it.
It it exists, we can do it.
