Forum Home Forum Home > Libraries > Schematic Symbols > CADSTAR
  New Posts New Posts RSS Feed - How to make a batch output an alternative.
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Topic: How to make a batch output an alternative.
    Posted: 03 Dec 2012 at 9:06am
Just a tip for those CADSTAR usersthat want to be able to batch output parts in Least, Nominal & Maximum dimensions and have a single component name but each different sized version of it as an alternative footprint.
(This is so that it can easily be selected within a design and changed I.E. when going from a prototype with Maximum to Least for production etc).
Output your batch with the environment setting as required and the component name will have L, N or M at the end of it.
Open the .CPA file within notepad and use search and replace for the following.
The text to search/replace is within the quote.
Least
Find
Quote L" ""
replace with
Quote " "L"
Nominal
Find
Quote N" ""
replace with
Quote " "N"
Maximum
Find
Quote M" ""
replace with
Quote " "M"
And save the .cpa file and import as usual.
Then you will get alternatives for each output.
This page was generated in 0.563 seconds.
