  New Posts New Posts RSS Feed - Advice sought for holes close on Mini DisplayPort
DaveCowl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Topic: Advice sought for holes close on Mini DisplayPort
    Posted: 08 Nov 2012 at 4:33pm
I have a sticky issue for a Mini DisplayPort connector with through hole pins.
The holes are recommended at 0.6mm but there are holes only 1mm apart!
So, in order to maintain a clearance of say 0.15mm between pads I get 0.85mm diameter pad (compared to recommended pad of 1.1mm for 0.6mm hole).
So, the question is, which 'rules' are best to follow.
I am inclined towards maintaining the pad to pad spacing and having a tight annular ring, rather than compromise pad to pad spacing for a larger ring and risk bridging.
Any guidance on this appreciated.
Cheers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 4:57pm
It looks like the pins are rectangular, max 0.25mm wide, so maybe I can also shrink the hole from 0.6mm to .55 or even 0.5mm...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 5:39pm
A 0.25 mm square pin size could fit easily into a 0.55 mm hole, but still that's a 0.95 mm pad per Proportional Padstack.
Download the IPC-7351 Padstack Calculator -
It has Least, Nominal & Most environment padstack calculations.
Great resource tool for when you're in a jam.
