  New Posts New Posts RSS Feed - Step Model Pin One Dot Missing
rrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrix Quote  Post ReplyReply Direct Link To This Post Topic: Step Model Pin One Dot Missing
    Posted: 10 Jul 2023 at 11:59am
When creating a STEP model, I see a pin one dot for the demo component, but not for the part I'm creating. I'm using version 23.09.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 12:08pm
This is an Inch Pitch SOIC and they don't have Polarity Dots.
They have a chamfered body along the side where Pin 1 is.
cc_ds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cc_ds Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 2:33am
Is there a option to add a pin1 dot into the 3d model for SOIC?
I have this component here and it shows a pin1 dot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 8:46am
The Chamfered Body along the Pin 1 side is for most SOIC's.
The Chamfered Body differentiates between Inch and Metric packages.
Only SOIC's with Metric pin pitch have polarity dots on 3D STEP models.
The plastic body on the TI SOIC in datasheet you listed has both a Chamfer and a Dot. That's a double polarity marker.
