Forum Home Forum Home > Libraries > Footprints / Land Patterns > CircuitStudio
  New Posts New Posts RSS Feed - Missing text string “.Designator” on the “As
hossa1c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hossa1c Quote  Post ReplyReply Direct Link To This Post Topic: Missing text string “.Designator” on the “As
    Posted: 16 Feb 2021 at 5:03pm
Circuit Studio by default has 2 top assemble layers
  • Assembly Text Top – the component name
  • Assembly Top – outline of the component
When I use Library Expert Enterprise Edition (2020.03) I use the default with the following changes.
  • Translator = “Altium Circuit Studio”
  • PADS Version = 9.3
  • 3D Model = tick
This generates a <name>.d & <name>.p
I then import <name>.d in to Circuit studio, but I have the following problems
  • I cant find a way to add my string “.Designator” to the .fxd part so it appears on any of the Assembly layers. This resolves to the to component Designator to help with placement.
  • The 3D step file isn’t attached to the component.
  • The “Top Solder” layer seems to contain the courtyard and some extra larges pads.
I've included the <name>.fpx file uploads/15524/fpx.zip
and the PcbLib which was the imported from the <name.d> uploads/15524/New_Parts.zip
cheers
Chris
This page was generated in 0.482 seconds.
