  New Posts New Posts RSS Feed - The better location for pattern origin
Batiskaff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Topic: The better location for pattern origin
    Posted: 09 Apr 2020 at 2:53am
I draw the footprint for https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=146274&DocType=Customer+Drawing&DocLang=English
I try to choose the place i will locate the pattern origin.
I usually set the origin in center.
Library Expert uses pin 1 for connectors by default.
Please, advice me the better solution, center or pin 1?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 8:21am
If you are using Library Expert Enterprise you can permanently change the Header Calculator origin to be in the Center.
Preferences > Components > Through-hole > Header > Origin > Pin 1 or Center of Extents or Center of Pins
If you are using Library Expert Pro you must select the "Settings" tab and change the Origin for every part manually and then select the "OK" button.
