  New Posts New Posts RSS Feed - Large slot size for 25 mils sq pin
USER2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote USER2 Quote  Post ReplyReply Direct Link To This Post Topic: Large slot size for 25 mils sq pin
    Posted: 27 Oct 2019 at 9:04pm
I am wondering if excessively large slot to multi-pin Part can be use to make it easy for hand insert?
Is there a IPC Rule that defines or limit the slot length size for given lead width ?
as to address excessive solder concern.
Please suggest the standard for reference.
Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 12:50pm
There is no IPC standard to address excessive solder.
However, IPC-J-STD-001 is the standard for solder joint goal acceptance.
This page was generated in 0.326 seconds.
