  New Posts New Posts RSS Feed - Third Placement Outline
jmeinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmeinert Quote  Post ReplyReply Direct Link To This Post Topic: Third Placement Outline
    Posted: 10 May 2019 at 11:32am
I am getting three placement outlines on chips with Mentor Graphics. I get the normal courtyard and component outlines, with an additional circle in the middle of the part with placement outline and height.
version 2019.2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 12:23pm
These are the outlines that Library Expert produces and you have control in Preferences > Drafting to turn them on/off with either check boxes or by turning the line width value to 0.00.
  1. Legend (silkscreen, trimmed around pins)
  2. Assembly (closed polygon)
  3. Component (using nominal dimensions)
  4. Terminals (where the Terminal Metal touches the pad)
  5. Courtyard
All of these go to different layers and are used for different applications.
Only the Legend is printed on the PCB.
The Assembly is used for a drawing.
The Courtyard is used for placement aid.
The Component and Terminal outlines should go on the same layer as they represent the physical package in the nominal material condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmeinert Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 9:08am
My Drafting setting are the same in 2019.02 as 2018.09. It looks as though the circle of the origin is being identified as a placement outline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 9:33am
The Origin Marker and Courtyard are on the same layer because they are both used for placement guides and they don't go out to fabrication and assembly.
This has been this way for the past 20 years.
The only way to fix it in V2019.03 is to turn off the origin marker in Preferences > Drafting > Courtyard.
You can manually add an origin marker on the assembly layer, but then they would appear in the assembly drawing.
This page was generated in 0.289 seconds.
