  New Posts New Posts RSS Feed - Library Expert 2018.06 Released!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2018.06 Released!!
    Posted: 16 Jul 2018 at 4:51am
Version 2018.06 was just released!!
NEW / ENHANCED:
  • Proteus:
    • Added the ability to output to PADS Layout Part Type .p and Decal .d files
FIXED:
  • Calculator:
    • Fixed an issue in the PQFN component family for parts under 1.60 mm in length, the incorrect terminal type was used
    • Fixed 2 issues in the PSON component family:
      • When Pin 1 was longer than the other pins, it caused the solder mask to swell for violating the Minimum Solder Mask Spacing Rule
      • For parts under 1.60 mm in length, the incorrect terminal type was used
  • Altium:
    • Fixed an issue with generating pads that are both rotated and offset
    • Script Naming will now allow you to use a period “.” in the name of your footprint and still have it generate that way in Altium
  • EAGLE:
    • Fixed a problem that could cause the first point to be called out twice for a polygon. This was causing an error to be thrown in Eagle, which will now go away.
  • Pantheon:
    • Adjusted the Attributes to remove @coord which was not being recognized
  • 3D STEP:
    • Fixed a conversion issue with off-unit (anything but mm) model output. This issue was primarily with TO-92 parts.
This page was generated in 0.191 seconds.
