  New Posts New Posts RSS Feed - No 3D STEP Polarity Marker on SOT23 Packages
Todd Manning View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Manning Quote  Post ReplyReply Direct Link To This Post Topic: No 3D STEP Polarity Marker on SOT23 Packages
    Posted: 14 Jun 2018 at 11:41pm
When I create a footprint for a SOT23 package there is no pin 1 indicator on the 3D model. The pin 1 indicator on the silkscreen and assembly drawing appear, but that is it.
Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 6:43am
Component manufacturers do not put Polarity Marking on SOT23 packages.
There are currently 3 pin pitches for SOT23 type packages -
  1. 0.95 mm
  2. 0.65 mm
  3. 0.50 mm
Send us a picture of a SOT23 physical package with a polarity marker.
You can Google search SOT23 Packages and you will not see any Polarity Marking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Manning Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 3:42pm
Thanks for the clarification. At some time in the past you must have included them as I have many SOT23 packages with the polarity marker. It doesn't worry me that its not there, it was just because I saw it on previous models that it concerned me that I had changed something for the indicator not to be there anymore.
Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 3:45pm
Yes, we originally had a Polarity Marker on SOT23, but when the industry produced a 0.50 mm pitch, there was no room on that micro-mini part.
We did the research and found out that CM's do not have Polarity Indication on any SOT23, so we removed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Manning Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2018 at 3:59pm
