  New Posts New Posts RSS Feed - DFN or SON Package? The Mfr. is Calling it DFN
Hassan Moaaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hassan Moaaz Quote  Post ReplyReply Direct Link To This Post Topic: DFN or SON Package? The Mfr. is Calling it DFN
    Posted: 31 Jul 2017 at 6:36am
I am trying to work on some packages but unfortunately tool not support as sample DFN 8 pin it support only DFN 6 pin is it possible to update tool with this package?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 6:42am
The part is and Small Outline No-Lead (SON with Tab).
It's not a Dual Flat No-Lead (DFN) as they only come in 2, 3 and 4 pin versions.
To see all the correct component family names, there is a document in this folder on your computer -
C:\Program Files (x86)\PCB Libraries\Library Expert 2017\Documents
The name of the documents are -
 - Library Expert Surface Mount Families.pdf
 - Library Expert Through-hole Families.pdf
stanleycayochok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanleycayochok Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 3:39am
Im using Library Enterprise Edition (2019.07) and the IPC-7351C Land Pattern Naming Convention.pdf could not be found in the Documents folder. Where can I get this pdf file?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 9:18am
There is no IPC-7351C Naming Convention. That Guideline is not released yet.
Download the PCB Libraries, Inc. Naming Convention here - uploads/3/Footprint_Expert_Land_Pattern_Naming_Convention.zip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 9:20am
You should really update to V2020.03 Library Expert Enterprise as it will be taken off-line next month and replaced with a brand new 100% rewrite V2021 Footprint Expert.
However, you might want to use V2020 during the learning curve.
