  New Posts New Posts RSS Feed - Library Expert Lite vs. IPC Version
HWgeek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HWgeek Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert Lite vs. IPC Version
    Posted: 25 Jan 2017 at 7:08am
From using the IPC calculator, it seems clear that they licensed a version of Library Expert from you.
I just tried using the latest PCB LE Lite 2017.06 from your webpage, and comparing it to 2016.08 from IPC.
Using a 1005 (EIA 0402) chip, capacitor and putting in the component dimensions the same in the two versions, gets two results.
Do you know if the IPC version will get updated?  I ask, since internally I can justify the IPC calculator (i.e. came from IPC) vs. PCB libraries, as being a private company.  And yes, its clear that its the same product, however, upper management is rather conservative.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 8:12am
V2017 uses the IPC-7351C proposed solder joint goals.
V2016 uses the IPC-7351B solder joint goals.
You can compare them in the Excel spreadsheets located in this folder -
C:\Program Files (x86)\PCB Libraries\Library Expert 2017\Documents
  • IPC-7351C (Proposed) Solder Joint Goal Tables v1.4
  • IPC-7351B Solder Joint Goal Tables v1.4
However, using V2017 you can reset the solder joint goals back to IPC-7351B by opening the Preference file -
IPC-7351B_DefaultPreferences.dat
However, if you are using Library Expert Lite you can't adjust the Preferences. Only LE Pro users can do that.
