  New Posts New Posts RSS Feed - Orientation Limited To 0-90 Degrees
NeilVPeers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilVPeers Quote  Post ReplyReply Direct Link To This Post Topic: Orientation Limited To 0-90 Degrees
    Posted: 08 Nov 2016 at 9:46am
I can successfully place a slotted pad at an orientation of 45 degrees but if I want to set it 135 degrees (to point the other way) I find I can't. The orientation defaults to 90 degrees. -45 degrees doesn't work either.
Is this a limitation or is there another way to do this?
Many thanks
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 12:23pm
Offsets are only allowed on the X (horizontal) dimension.
Pad orientations are limited to 0, 90, 180 or 270 (depending on the shape).
Round or square - 0 only.
Oblong, rectangle - 0 & 90.
D shape an other asymmetrical pads can be 0, 90, 180, or 270.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilVPeers Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 5:07am
Thanks Jeff,
I am able to set a pad to 45 degrees which would suggest that the orientations are not limited to multiples of 90 degrees.
What I cannot do is set it to -45 (or 135 etc)
... and I still need to be able to do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 8:46am
Pad stack orientations are limited as previously noted.
Pin orientations aren't.  Query the pin (left click, right click) then select Properties.
You can set the pin orientation there.
