  New Posts New Posts RSS Feed - How To Genereate CAPAE Footprint?
Sujith View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sujith Quote  Post ReplyReply Direct Link To This Post Topic: How To Genereate CAPAE Footprint?
    Posted: 12 Sep 2016 at 6:23am
I am new to this tool.
I was trying to generate a footprint foor SMD Aluminium Capacitorm but no success !
whats wrong am doing? please help
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:09am
Do you see the blue dots in the dimensions?
Only enter any 2 of 3 that you want and never enter all 3. You'll get bad results due to over calculation of tolerances.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sujith Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 8:43am
Ahh..yes, I missed it.
It got worked now..Smile.
In the component data sheet by the mafr the pads values are : L=5.5, W=1.2+-0.3, P=6.7 . is this values are based on nominal or most or least?
and the generated footprints measurement were :
Most             Nominal        Least
L=6.83         L=6.46         L=6.12
W=2.7          W=2.52        W=2.31   other dimensions like outline and courtyards also varies, i didt checked.
here I got the width of the pads entirely wrong it seems?
and its a bit confusing which footprint (n,m,l) to use , in the internet most people suggests to use nominal footprints.
Actually what is the best practice to follow?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 9:08am
Most people use Nominal Density Level, which is a default setting.
Maximum Density is used for space satellites.
Least Density Level is used for RF design or extremely dense designs.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sujith Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 9:36pm
Ok...thanks for the info.
but how to get the correct pad width? instead of 1.2 +-0.3 am getting 2.51
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:38am
The solder joint goals in LE Lite are in the tab Terminal > Density Level > Toe, Heel and Side.
You can control the entire solder joint by adjusting those values.
