  New Posts New Posts RSS Feed - Reset Back to IPC Default
caclark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Topic: Reset Back to IPC Default
    Posted: 07 Sep 2016 at 8:30am
I have been tasked with doing a comparison between our company component library for a few device types (our own .dat file we have changed from IPC standard over the last several years to fit our mfg requirements) and that of IPC directly.
However I do not see how to reset the Default Preference Source back to "IPC Internal Defaults".
How can I reset it? It will not allow me to type in the preference field to change the name or location of this source file.
And I do not know where the program has located the "IPC Internal Defaults" .dat file on my computer.
I have the latest version installed 2016.10
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 10:44am
In the Preferences menu select "New" to go back to IPC-7351B
In Preferences menu select "Open > IPC-7351C Proposal.dat" to open the new standard.
The default Toe, Heel and Side values for both standards are located in this Library Expert folder:
C:\Program Files (x86)\PCB Libraries\Library Expert 2016\Documents
  • IPC-7351B Solder Joint Goal Tables v1.3.xlsx
  • IPC-7351C (Proposed) Solder Joint Goal Tables v1.3.xlsx
You can open these spreadsheets to do a side by side comparison.
You can always change the Toe, Heel and Side values to whatever your manufacturer requires.
