  New Posts New Posts RSS Feed - Suitable Licence for Cadence OrCAD
Hassan Moaaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hassan Moaaz Quote  Post ReplyReply Direct Link To This Post Topic: Suitable Licence for Cadence OrCAD
    Posted: 05 Sep 2016 at 1:44am
If I need to format "Cadence OrCAD" what license  should i have ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 6:49am
OrCAD PCB is what you want and I believe we're selling V2017 right now because it's coming out next month in October with Symbol Expert and the OrCAD Capture interface is already completed.
In the meantime, you will use the current release V2016.10.
Get a 30-day Trial License for free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hassan Moaaz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 2:22am
1.I want to import FPX file to trial version and produce OrCAD PCB is it available?
2.I notice that all other option expect surface mount and through hole was hyperlink to site.
Appreciate your support and help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:48am
It looks like the Library Expert Pro installation you have can no longer see the USB Key, and is running as a Viewer. You can confirm this by going to "Help" and "Installed Options" - if this is the case, you won't see any options enabled. Let's talk offline to troubleshoot. I'll send you an email.
