  New Posts New Posts RSS Feed - SMD (Solder Mask Defined) and NSMD Pads
drj-bbe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Topic: SMD (Solder Mask Defined) and NSMD Pads
    Posted: 24 Sep 2015 at 5:45pm
Hi Tom:
I know BGA land pattern design have two method, SMD(solder mask defined) and NSMD (non-solder-mask-defined), NSMD will be good than SMD for BGA pad to increase solder joint reliability.
What about other components? chip, sop, connector and etc.
Is NSMD also priority option for most components?
Is there any related description in IPC/JEDEC standard?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 9:36pm
BGA pad size and solder joint relation is totally different than Chip, SOP and Connectors.
The NSMD BGA pad stack is necessary for the Ball to fully collapse around the pad edge securing it to the PCB -
The SMD (Solder Mask Defined) BGA pad stack prevents the Ball Collapse -
The BGA ball melts during reflow and other component leads do not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote drj-bbe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2015 at 10:26pm
So, which method will be better for PCB land pattern soldered BGA?
I have seen a describtion in IPC-7093 6.1.3.6 solder mask design. NSMD is better than SMD on QFN solder joint strenth. Should I assume that NSMD is first option for other chip, sop and connectors.
What about your opinion?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2015 at 5:20am
NSMD is normally used on every SMT pad due to registration tolerance of +/- 0.05 mm.
You do not want any solder mask on the pad so the minimum solder mask opening should be 0.05 mm.
The exception to this rule is Flexible Circuit libraries normally have a 0.05 mm solder mask over the Toe and Heel of the pad to act as an epoxy glue to hold the pad down while flexing the board.
