  New Posts New Posts RSS Feed - Naming Convention for PTH Headers
vgalindo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vgalindo Quote  Post ReplyReply Direct Link To This Post Topic: Naming Convention for PTH Headers
    Posted: 30 Apr 2015 at 12:35am
I found duplicate names in PTH connectors using the Footprint Naming Convention.
The W identifier does not distinguish between circular or square Lead Shape, this create the same footprint name for different connectors; eg,
HDRV2W65P254_2X1_508X254H945 could have:
- a 0.65mm
square lead shape and hole of 1.12mm, or
- a 0.65mm circular lead shape and hole of 0.85mm
It would be interesting to specify the Lead Shape in W identifier?
Thank you very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2015 at 5:13am
Please start using the new IPC-7351C Footprint Naming Convention for all connectors.
MfrName_MfrPartNumber
Mattylad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattylad Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2015 at 1:15pm
Has C been released\published yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2015 at 1:32pm
IPC-7351C is deep in development. Our next meeting is Monday morning.
It will go out to the entire 1-13 Land Pattern sub-committee next week for review and feedback.
It will go through final Executive Committee approval in September at SMTA in Rosemont, IL and then head out for 30-day ballot vote with the 1-13 Land Pattern sub-committee.
Then the new Guideline will go into type setting for first article proof and then in February 2016 production should begin.
The IPC-7351C Guideline is 90% written but the last 10% will take a couple months and the evaluation and editing / approval phase also takes a couple months. Voting could take 90 days if it doesn't pass on the 1st vote.
