  New Posts New Posts RSS Feed - Pad Stack Always X Exceed Y
PLTcbv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Topic: Pad Stack Always X Exceed Y
    Posted: 25 Sep 2014 at 4:58am
When building a Oscillator Corner Concave.
In the generated padstack the Y width exceeds the X width and has a 270 degree rotation.
The pad could better be generated with a 0 degrees rotation and a X width exceeding the Y width.
This keeps the Pad Stack Library cleaner with less entries.
Regards,
Wim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2014 at 10:39am
In our tool it doesn’t matter. Pin orientations will change with part re-orientation.
 Things like this are cleaned up when converted to the target CAD tool format.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLTcbv Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2014 at 12:13am
This is the default view when making a part.
The pad orientation is "270" and should be "0".
If you use the Padstack Designer you can't create an offset in the Padstack when Y exceeds X.
So i.m.o. always let X exceed Y.
If you convert to Expedition ASCII out rotations are not cleaned up.
So we have one pad with orientation "0" and one pad with "180"
This page was generated in 0.673 seconds.
