Through Hole Part Has Stencil Info in Pad Stack |
PLTcbv
Joined: 21 Aug 2012 Location: the Netherlands Status: Offline Points: 134 |
Topic: Through Hole Part Has Stencil Info in Pad StackPosted: 25 Sep 2014 at 1:37am |
If I create a Through Hole part with the LE Lite 2014.11 and do an Expedition ASCII out the part gets stencil information in the Padstack.
Maybe this is because it is marked as Surface mount. Stencil Width can be selected in the terminal window when building a part. ![]() For normal Through Hole parts this is not necessary. Only for PIP (Pin In Paste) parts. Please make it selectable to switch it on/off. Wim.
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6031 |
Posted: 25 Sep 2014 at 10:50am |
The Through-hole pad stack defaults to No Paste Mask. However, if you want Paste Mask for "Pin-In-Paste" technology, simply add a Paste Mask value. |
PLTcbv
Posted: 26 Sep 2014 at 12:20am |
This is the default and it creates a Paste Mask.
This is in Library Expert Lite 2014.11
