  New Posts New Posts RSS Feed - Add Solder Mask definition for Flex IPC-2223
Message Reverse Sort Order
tboyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tboyer Quote  Post ReplyReply Direct Link To This Post Topic: Add Solder Mask definition for Flex IPC-2223
    Posted: 09 Sep 2014 at 11:28am
Maybe not what allot of companies are dealing with
but to design a pattern for the Flex of a Flex board or Rigid-Flex
board requires modifying the solder mask in such a way that
your software currently cannot build to. See figure 9 of IPC-2223.
I think this would save me valuable time because I currently
have to use the software to create the pattern then go
into Layout pattern tool and modify the pad and solder mask.
Then leave a note in the library that this pattern was modified
for Flex. how it was modified and what it looks like is only
visible through the Layout tool.
