  New Posts New Posts RSS Feed - Import from PADS Layout
LinneaSjoholm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LinneaSjoholm Quote  Post ReplyReply Direct Link To This Post Topic: Import from PADS Layout
    Posted: 17 Jun 2014 at 12:56am
Hi! I'm using PADS Layout and can import from PCB Library Expert to PADS, but I'm having problems with importing to PCB Library Expert from PADS. How do I do that?
Regards,
Linnea
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2014 at 2:20am
The Library Expert does not import from the native CAD formats back into FPX format. The Library Expert maintains data in a CAD neutral FPX format, as well as user preferences (DAT files) and when you need to rebuild your libraries to a different format, or with different settings, it's a snap.
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote LinneaSjoholm Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2014 at 12:14am
I'm using PADS Layout version 9.4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2014 at 9:03am
You can use the new V2014.04 PADS to CAD Translator to convert PADS files to any other CAD tool, but you cannot import any CAD Tool Library data into Library Expert.
Library Expert auto-generates footprints on two pieces of data -
  1. Component Dimensions
  2. User Preference Rules
Your PADS Layout library does not have either of these two items.
This page was generated in 0.672 seconds.
