  New Posts New Posts RSS Feed - Rounded Rectangle and D-shaped Pads for Altium
Ryan Rutledge View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ryan Rutledge Quote  Post ReplyReply Direct Link To This Post Topic: Rounded Rectangle and D-shaped Pads for Altium
    Posted: 12 Mar 2014 at 3:19pm
Rectangle, round, and oblong pads come through OK, but rounded rectangle and D-shaped are atrociously disfigured. I am following the recommended Altium Designer output settings as found in the help files.
Perhaps PADS 2005.2 and 2007.0 do not support these pad shapes, but these results are pretty bad. The pad shape is manually created with poor resolution, along with the expanded solder mask shape.
At least the rounded rectangle shape has been supported by Altium Designer for all the years I've used it, so I would prefer to not have to restrict myself to rectangle shapes then do an additional touch-up step.
Post Options Post Options   Thanks (1) Thanks(1)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2014 at 5:02pm
Hi Ryan,
Make sure you select PADS Layout V9.3 ASCII so that it uses native rounded rectangles.
Rounded Rectangle pad shape were introduced in PADS V9.1.
So if you're using PADS Layout V2005.2, rounded rectangle didn't exist yet.
If you're using Altium 13.3 or 14.2 set your default CAD output to PADS Layout V9.3. That is what our new V2014 Library Expert will default to.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ryan Rutledge Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2014 at 1:07pm
I have FPX 2013.20. Is this the latest?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2014 at 1:45pm
Yes, it's the latest release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Rutledge Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2014 at 2:21pm
Thank you for the correct settings. They worked nicely.
