  New Posts New Posts RSS Feed - Does Library Expert Support JEDEC MO-241?
caclark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Topic: Does Library Expert Support JEDEC MO-241?
    Posted: 20 Feb 2014 at 7:44am
My company uses a lot of the JEDEC MO-241 packages. They are almost the same as your current QFN, with the exception that all but 2 pins are removed on 2 opposing sides of the device, and a specific dimension is used for placement of the remaining pins (not usually in line with the pitch value of the other pins).
Can this either be added to the list of standard parts that can be used, or added as another option to the current QFN.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2014 at 7:49am
You can "Hide" or "Delete" QFN pins.
The JEDEC MO-241B are "Standard" IPC components that can be built using the Library Expert calculator.
Just create the part with no missing pins. Then select the pins you want to Hide or Delete and Right Mouse click and make your selection.
This page was generated in 0.637 seconds.
