  New Posts New Posts RSS Feed - 4-Pin DFN Pin Reorder
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: 4-Pin DFN Pin Reorder
    Posted: 08 Dec 2013 at 8:01am
I tried to renumber pins on a DFN 4 pin and it states us pin reorder.
Where is the pin reorder command?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2013 at 10:58am
This is a bug  for 3 and 4 pin DFN's.
Andre.Mylle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andre.Mylle Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2014 at 9:37am
For DFN, I note this:
1. For 3,4-pin DFN: whatever I put as Orientation in the component settings Up or Left, pin1 appears on the opposite side.
2. In the setup, there is no distinction on orientation for 2-pin DFN and 3,4-pin DFN devices.
I think this is incompatible with the zero orientations from IPC7351C, lev A or B.
Is this the same bug?
Version 013.17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2014 at 12:13pm
This is new.
The default orientation for the 3 pin DFN appears to be 180 degrees off.
The others look OK though.
