  New Posts New Posts RSS Feed - SMT Padstack Designer Not Loading X Dimensions
rickdehart View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote rickdehart Quote  Post ReplyReply Direct Link To This Post Topic: SMT Padstack Designer Not Loading X Dimensions
    Posted: 01 Aug 2013 at 4:18pm
If I try to create a padstack in the FP Designer with all the options, then reload that padstack to make changes, I loose the X dimensions.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2013 at 10:07am
Will be fixed in next release.
Post Options Post Options   Thanks (1) Thanks(1)   Quote rickdehart Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 8:43am
X Dimensions are showing up now.
Post Options Post Options   Thanks (1) Thanks(1)   Quote rickdehart Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 8:45am
Stencil Reduction is not working.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 11:44am
Appears to be ok.
Do you have 'Stencil' selected as the top layer.
Post Options Post Options   Thanks (1) Thanks(1)   Quote rickdehart Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 11:56am
Here is a snap shot of the stencil top selected, Stencil % = 50.  I also have the mask set for 0.05 on both X and Y.
I see no stencil reduction indicated in the name.
I see no stencil in the View Layer.
I do see stencil in the Details, but it is not reduced.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 1:33pm
Your'e trying to add a stencil pattern to a pad that is too small for a stencil pattern.
Note the 'Stencil Pattern' check box.
Anything below 70% defaults to a pattern (reserved for thermal tabs).
You need to get up to about 2mm before a thermal tab is recognized.
Uncheck the box and you'll see your stencil.
Post Options Post Options   Thanks (1) Thanks(1)   Quote rickdehart Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 3:02pm
I understand what is going on now.  I like the fact that you have built in a minimum Stencil pattern.
Could you provide a warning, disable the stencil pattern checkbox, or simply ignore the pattern checkbox if the pads are too small?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 6:20pm
I knew you were going to say that.
I should have added that a fix is in the works but won't show up for about a month.
Rick, it looks like you are pushing a lot of buttons and I appreciate that.
Thanks for all the reports you're submitting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickdehart Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2013 at 8:28am
We are actively using 2012 for 5-7 cells a week.  I would like to move my guys up to 2013, but I need to make sure everything is working as expected.  Thank you for all the quick fixes.
This page was generated in 2.953 seconds.
