  New Posts New Posts RSS Feed - Standard Chip Package Case Codes & Dimensions
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2021 at 8:32am
Read the User Guide in the main installation folder under "Documents".
  • Charter 1 Footprint Expert Console Options
  • Charter 2 Footprint Expert Calculator Options - Pad Stack Rules
  • Charter 3 Footprint Expert Calculator Options – Drafting
  • Charter 4 Footprint Expert Calculator Options – Fiducials
  • Charter 5 Footprint Expert Toolbar Icons and Menu Options
You cannot edit the program Master Options. You need to create your personal option files (as many as you want).
Select File > Save As > Your Master Options .opt
AnonAnon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AnonAnon Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 5:41am
Please excuse me if you've answered this a thousand times but I'm looking to find which standard defined the "Least" and "Most" limits for each footprint. I can see IPC-SM-782 defines the nominal and references equations in a section 3.3? I am happy to purchase the standard but wanted to ensure it contained the correct information before I purchase.
Do the IPC standards only provide the nominal and one has to calculate the limits?
Kind regards,
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2022 at 10:01am
IPC-7351B contains the 3-Tier Density Levels for Land Patterns.
However, that document is 12 years old and out of date and it took information from the 1987 IPC-SM-782 which is obsolete.
The solder Joint values are way too robust for today's technology.
Footprint Expert solder joint goals are derived from IPC J-STD-001 standard as it's the main standard that all other standards are built upon.
This page was generated in 1.406 seconds.
