  New Posts New Posts RSS Feed - SOP, TSOP, SSOP and TSSOP
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: SOP, TSOP, SSOP and TSSOP
    Posted: 8 hours 35 minutes ago at 5:39pm
For this part"SST39VF3201C-70-4I-EKE-T" in this datasheet:
Has a package name of TSOP, however this package is not found in Footprint Expert.
What should I do in this case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 44 minutes ago at 6:30pm
TSOP = Thin Small Outline Package
TSOP was created by a the marketing department of a component manufacturer to refer to the low height profile of 1.60 mm.
Since this was released years ago, the SOP package Height has changed to 1.20 and then to 1.00 and then to 0.80.
Their marketing plan only worked for a couple years.
TSOP is really just a metric pin pitch SOP.
Manufacturers have referred to the SOP as:
  • TSOP - Thin Small Outline Package
  • SSOP - Shrink Small Outline Package (Fine Pitch)
  • TSSOP - Thin Shrink Small Outline Package (Thin and Fine Pitch)
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 22 minutes ago at 6:52pm
so is  this mean all these pacakges(TSOP-SSOP-TSSOP) should be created by SOP PCB tool package?
