  New Posts New Posts RSS Feed - Question about Oscillator, L-Bend definition
KoryJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KoryJ Quote  Post ReplyReply Direct Link To This Post Topic: Question about Oscillator, L-Bend definition
    Posted: 05 Jun 2013 at 9:46am
Hi.
Is the value for E2 supposed to be the NOM dimension for the center of the contact surface on the lead/pin?  I am using this land pattern, not for an oscillator, but for an LED that has "L" leads (http://www.cree.com/~/media/Files/Cree/LED%20Components%20and%20Modules/HB/Data%20Sheets/CLP6CFKB%28933%29.pdf - see sheet 7).  It is not entirely clear if this is for the body or leads.
Kory
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2013 at 12:10pm
Yes, the red * (required entry) is located in the "Nominal" column.
