  New Posts New Posts RSS Feed - Non-plated through-holes
tgrodnicki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tgrodnicki Quote  Post ReplyReply Direct Link To This Post Topic: Non-plated through-holes
    Posted: 13 Jul 2017 at 4:53am
Non-plated through-holes created by PCBLE (2017.14) are exported to KiCad as Through-hole (plated).
I would like them to be "NPTH, Mechanical" - can it be implemented in future?
For now, I correct this in KiCad, but must also increase the size of the pad to match the hole as the program complains "Incorrect value for pad drill: pad drill bigger than pad size".
If possible this also should be changed.
jayfrancis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jayfrancis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2020 at 10:48am
Has there been any work done on this?
I've run into the same issue.
Library Expert Enterprise Edition (2019.07).
Also, the keepouts for the NPTH holes are not carried through to KiCad either.
As an example, check Segger 8.06.16
--Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 9:44am
The new 100% rewrite V2021 Footprint Expert will resolve all issues. It's release date is November 1.
We're not fixing any bugs in the old V2019 which will be taken offline in a month.
This page was generated in 0.312 seconds.
