  New Posts New Posts RSS Feed - Mounting Hole Gap?
Mounting Hole Gap?
dannicholson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannicholson Quote  Post ReplyReply Direct Link To This Post Topic: Mounting Hole Gap?
    Posted: 21 Oct 2014 at 5:20am
For a non-plated mounting hole with vias, how do I change the gap between the annular ring and the non-plated drill?
Is there a setting to make the gap wider?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2014 at 12:44pm
I'm assuming you mean for the anti-pad?
If you're using the 'proportional' fabrication level there is no available adjustment.
In the 'User' Fab level you can set all aspects of the pad stack.
This will change in the next software version where 'proportional will be the only method for both user and default but all controlling values will be available.
