Forum Home Forum Home > Libraries > Footprints / Land Patterns > OrCAD Layout
    Posted: 05 Jan 2025 at 5:20pm
  1. Silkscreen
  2. Assembly
  3. Courtyard
  4. Origin
  5. Component
  6. Terminals
