  New Posts New Posts RSS Feed - Library Expert is Not Creating STEP for CAPMP's
acmenet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acmenet Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert is Not Creating STEP for CAPMP's
    Posted: 26 Jan 2021 at 6:59am
Seem the Molded Polarized Cap will not create a STEP model.
It works for normal Molded Capacitors, and Molded Resistors.
Using version 20.03.
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 9:49am
Can't reproduce the error. Make sure that the "D" dimension is at least 0.70 mm larger than the "D1" dimension (minimum).
Post Options Post Options   Thanks (0) Thanks(0)   Quote acmenet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 1:24am
For me still not playing ball, i did have by d1 less than 0.7mm smaller, but still no good
creates a non polorized fine with same settings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 9:25am
We'll fix this in the new V2021 Footprint Expert next week.
There should be a new Beta release of all versions next week so we can test and fix all the features.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote acmenet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 9:45am
Thanks Tom.
Thought i was going mad, when you said it worked for you.  Maybe its just the combo i used
This feature used to work fine, but tbh i have not created one of these for a while.
Look forward to the new release
Kind regards
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 10:43am
Both Library and the new Footprint Expert are working OK for me, but we need to reproduce your issue.
We start the process of reviewing bug issues for the new V2021 release the week of February 8, while V2021 is in Beta Release.
Once all known bugs are fixed, we will officially release V2021 Footprint Expert.
This page was generated in 1.609 seconds.
