IPC-7351 Padstack Naming Convention |
Post Reply | Page <1234> |
Author | |
PLTcbv
Advanced User Joined: 21 Aug 2012 Location: the Netherlands Status: Offline Points: 134 |
Tom,
When do we use the"u" for a padstack? Looking at the document I see: u = User Defined Contour (Irregular Shape) Some examples in the document: - s300p190r25cul50 = square 3.00 land, square paste 1.90, corner radius 0.25, upper-left chamfer 0.50 - u480p4s152cul50 = 4.80mm Square Land with 4 Paste Mask Squares 1.52mm each with 0.50mm Chamfer in Upper Left corner They are both squares with a upper-left chamfer, so an Irregular Shape. Why is the first a "s" and the second a "u"? |
The letter "u" is used twice.
If you see the letter "u" as the very 1st character it represents "user defined pad shape". c = Circular s = Square r = Rectangle b = Oblong u = User Defined Contour (Irregular Shape) d = D Shape (Square on one end and Circular
on the other end) If you see "u" in the middle of the padstack name it represents "Upper" when chamfered or radius corners are used. bl – bottom left blr – bottom left &
right ubl – upper and bottom
left ubr – upper and bottom
right |
PLTcbv
I understand that the letter "u" is used twice.
I was just wondering when to use a "s" and when a "u". If you look at s300p190r25cul50 and u480p4s152cul50 in the document these are both a Square land with 0.5 mm Chamfer in Upper Left Corner, but sometimes the padstack starts with "s" and sometimes it starts with "u". |
To use "u" for a square pad with a corner chamfer is the wrong application of the IPC padstack naming convention.
If the first character is "u" the pad shape is irregular (free form) and not square. Are you telling me that the FP Designer produces a padstack name of u480p4s152cul50? |
PLTcbv
No, I was looking at the begin off this post.
Look at: Examples of a square land with 3 rounded and 1 chamfered corner (for Thermal Pad) and Example of Thermal Pads for QFN, SON, QFP and SOP Both square pad different notation.
Well then thanks for pointing that out so we can get the record straight.
"u" should not be used for the primary letter for square pads with chamfers. |
PLTcbv
Padstack Naming Convention:
Chamfered & Rounded corner modifiers are used to indicate which corner(s) are modified.
Order of precedence has been given to the first 4 modifiers.
Modifiers: If you use the Padstack Designer in PCB LE Lite the modifiers are: ll - Lower left lr - Lower right ul - Upper left ur - Upper right Which is correct bl or ll / br or lr? |
Once Jeff gets back from vacation in a week, we'll fix this padstack naming convention to match IPC-7351.
Thanks for reporting this! |
Nick B
Admin Group Joined: 02 Jan 2012 Status: Offline Points: 1906 |
This was fixed in 2013.11, to be released within the next couple days.
PLTcbv
I'm looking at 2013.12 and it looks like it was't fixed.
Still "Lower Left" and "Lower Right". Should be according IPC "Bottom Left" and "Bottom Right".
Tweet |
