  New Posts New Posts RSS Feed - Globally Turn Local Fiducials On/Off
craig4tone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Topic: Globally Turn Local Fiducials On/Off
    Posted: 26 Jan 2017 at 8:28am
I'm running 2017.06
I created a QFP and unchecked the "Add Fiducials" checkbox and the part is created without fiducials.  If I go back and double-click that part in the Library Editor window, the fiducials are now visible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 8:35am
Preferences > Component Families > QFP > Local Fiducials > Add Fiducials when Pitch is Less Than __?
Same with BGA's.
Watch this video -
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 8:49am
Understood but maybe I am wrong in assuming that the "Add Fiducials" checkbox is an override?  If it is not, what purpose does it serve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 8:56am
If you have the Preferences set to a low value and you want to add Local Fiducials to a custom part you select the Add Fiducials button and Save to FPX and the Fiducials are saved in the FPX file until you unselect the box and resave the data to FPX.
By default, the Local Fiducials are not saved in the FPX file because they are automatically inserted by Preferences.
But if the fiducials do not appear and you turn them on, that means you want to override Preferences and save to FPX will store them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig4tone Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 8:58am
I see ... so "Add Fiducials" is only an override to add them, not remove them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 9:00am
Correct
This page was generated in 1.063 seconds.
