  New Posts New Posts RSS Feed - Generate Libraries from command line
Joris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joris Quote  Post ReplyReply Direct Link To This Post Topic: Generate Libraries from command line
    Posted: 10 Oct 2012 at 7:09pm
It would be great to be able to generate libraries from command line, for example:
FPX_2012.exe --buid --env=N --prefs=DefaultPreferences.dat --library=Maxim.fpx --translator=Altium --output-dir=/maxim
A possible use case is automatically building libraries on a post-commit svn hook. This would allow for completely automated library generation when a new version of the fpx library is committed to svn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2012 at 9:10pm
Thanks for your input. We talked about setting up command line function. Most likely won't happen anytime in the near future, earliest maybe 2013. Since this will present a fundamentally new way of creating libraries, if implemented, I wouldn't be surprised that IF this were to get implemented, it get configured as a separate licensed feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joris Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 4:37pm
Thank you for the reply. I understand, that makes sense.
We would be very interested in this feature, even though it would be a little further down the road.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joris Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2013 at 8:58am
Hi Nick, any updates on this subject?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2013 at 9:30am
A command line option is unlikely to happen this year, the POD project is a priority.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joris Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2013 at 1:45pm
Ok Thanks!
This page was generated in 0.345 seconds.
