  New Posts New Posts RSS Feed - Footprint Expert 26.07 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 26.07 Released!!
    Posted: 01 Jul 2026 at 4:42pm
Version 26.07 was just released!!
Fixes & Enhancements:
  • Calculators:
    • Through-hole:
      • Removed all instances of a Nominal dimensions from thru-hole footprint names
    • Side Concave Package:
      • Removed the Assembly Polarity Marker from all non-polarized footprints
      • When the Nominal Height and Tolerance is entered to create the Max Height the footprint name used the Nominal dimension
  • Courtyard Excess and Silkscreen Controls:
    • Quality control for all Surface Mount and Through-hole calculators and FP Designer Courtyard, Silkscreen controls and spacings including:
      • Line Widths, Clearances, Map-to, Allow Expanded Silkscreen, Offset Silkscreen Away from Body, Expand Courtyard to Include Silkscreen, Contoured Courtyard
  • FP Designer:
    • Options for 3D Model Polarity was not changing when the footprint was rotated
    • Pad Stack Manager:
      • Added Chamfer Corner feature on square through-hole pads
      • Changed the Keep-out Pad shape option to reflect the hole shape. Enlarging the keepout created an oblong shape.
      • Added these modifiers to the pad stack names:
        • o = Offset Pad and Solder Mask with the same + / - value
        • om = Offset Solder Mask only + / - value
        • op = Offset Paste Mask only + / - value
  • CAD Tool Interfaces:
    • Batch building PADS-To-CAD unique parts was allowing duplicate footprints for the translators
  • Guideline:
    • Updated the Pad Stack Naming Convention to match FP Designer
    • Added EIA / IEC chip case codes to the tables for easy cross reference
    • Add chamfered square through-hole pad shapes
This page was generated in 0.201 seconds.
